The exercise reads: Express the power series for $\large \frac{z}{\sin (z)} = \frac{2 i z}{e^{iz} - e^{-iz}} $ in terms of Bernoulli numbers.
I am given in a previous exercise that the Bernoulli numbers are defined by $$ \frac{z}{e^z - 1} = \sum_{n = 0}^{\infty} \frac{B_n}{n!} z^n, $$ where $ B_n $ is the $ n^{th} $ Bernoulli number. I've been looking for a clever way to write $ \;\large\frac{1}{e^{iz} - e^{-iz}} \;$ in the form of a linear combination involving terms of the form $\; \large\frac{1}{e^z - 1}\; $, but haven't had any luck. Any pointers would be greatly appreciated!
Mittens
  • 46,352
tylerc0816
  • 4,243
    You could clear the denominator to get $\exp(iz)\frac{2iz}{e^{2iz}-1}$ and you know the fraction's expansion in terms of bernoulli numbers so you can multiply by the expansion of $\exp(iz)$ and match coefficients of $z^n$ – Alex R. Dec 22 '12 at 04:21
  • @Alex I did notice this earlier. I tried it and couldn't find any sort of pattern in the expansion. I believe this would be a good solution for a computer though. – tylerc0816 Dec 22 '12 at 04:40
If you start with $f(z):=\frac{z}{e^z-1}=\sum_{n=0}^\infty B_n\frac{z^n}{n!}$, consider what $f(z)+f(-z)$ is. You'll get a sum of only even bernoulli numbers. Now notice that
$f(z)+f(-z)=\frac{z(e^{t/2}+e^{-t/2})}{(e^{t/2}-e^{-t/2})}$
which you can reverse engineer to verify (multiply by the right ratio which equuals 1). This essentially gives you an expansion for $\cot(z)$ in terms of the even Bernoulli numbers. However you want $\csc(z)$. This is amenable by recalling that
$\cot(z)-\cot(2z)=\csc(2z)$
So subtract the power series to get your result.
The correct answer is:
$$\csc(z)=\sum_{n=0}^\infty \frac{(-1)^{n+1}2(2^{2n-1}-1)B_{2n}}{(2n)!}z^{2n-1}$$
Alex R.
  • 33,289
