Recently, I have encountered a problem:
Given a ring $R$. Prove that:
1) If $x \in R$ has two distinct right inverses, it has infinitely many right inverses
2) If $x \in R$ has a unique right inverse, it is invertible.
3) If $R$ doesn't have any zero divisors, every left or right unit is a unit.
For the first task, I can only see an example: Given ring $R$ with the multiplication $x . y = x$, then it is easily seen that $1$ has infinitely many right inverses. However, it doesn't provide any insights for me to reach the solution.
For the second task, I guess that if $x$ has the unique right inverse $y$, then $y$ must also be the inverse of $x$. However, I don't have a way to get it.
For the third task, I think that it is not necessary that the left/right inverse of $x$ must be the inverse of $x$. However, for this case, I can't go any further.
Please consider the problem and give me some hints. Any help is appreciated. Thank you for reading.
