Question: Given a bounded lattice $\mathscr{L}$ with top $T$ and bottom $B$, is it the case that any sublattice of $\mathscr{M} \subseteq \mathscr{L}$ which is bounded must also have $T$ as its top and $B$ as its bottom?
Or could other elements from $\mathscr{L}$, some $T'$ and $B'$, assume the role of the top and bottom of $\mathscr{M}$?
I think the answer to the latter question is no, but I am not sure if my idea for the proof is actually correct given the definitions of lattice and bounded lattice, which I am not sure I fully understand.
Note: This is a follow-up to a previous question.
Attempt: By definition or something else, because $\mathscr{L}$ is bounded, the empty join must be $B$ and the empty meet must be $T$. Any meet operation which has a different empty meet would be a different/non-equal meet operation. Any join operation which has a different empty join would be a different/non-equal join operation. (Because this would imply that they were defined differently.)
Thus, if the bottom of $\mathscr{M}$ were $B' \not=B$, then that could only be the case if the join operation on $\mathscr{M}$ were different from the join operation on $\mathscr{L}$. Thus the ground set of $\mathscr{M}$ may be a subset of the ground set of $\mathscr{L}$, but since the join operations are different, $\mathscr{M}$ is not a sublattice of $\mathscr{L}$.
Likewise, if the top of $\mathscr{M}$ were $T' \not=T$, then that could only be the case if the meet operation on $\mathscr{M}$ were different from the meet operation on $\mathscr{L}$. Thus even though the ground set of $\mathscr{M}$ is a subset of the ground set of $\mathscr{L}$, and both are posets with respect to the same partial order, their meet operations must necessarily be different, and therefore $\mathscr{M}$ cannot be a sublattice of $\mathscr{L}$.
