I found this here:
Sum Problem
Given eight dice. Build a $2\times 2\times2$ cube, so that the sum of the points on each side is the same.
$\hskip2.7in$enter image description here
Here is one of 20 736 solutions with the sum 14.
You find more at the German magazine "Bild der Wissenschaft 3-1980".
Now I have three (Question 1 moved here) questions:
  1. Is $14$ the only possible face sum? At least, in the example given, it seems to related to the fact, that on every face two dice-pairs show up, having $n$ and $7-n$ pips. Is this necessary? Sufficient it is...
  2. How do they get $20736$? This is the dimension of the related group and factors to $2^8\times 3^4$, the number of group elements, right?
    i. I can get $2^3$, by the following: In the example given, you can split along the $xy$ ($yz,zx$) plane and then interchange the $2$ blocks of $4$ dice. Wlog, mirroring at $xy$ commutes with $yz$ (both just invert the $z$ resp. $x$ coordinate, right), so we get $2^3$ group lements. $$ $$ ii. The factor $3$ looks related to rotations throught the diagonals. But without my role playing set at hand, I can't work that out. $$ $$ iii. Would rolling the overall die around an axis also count, since back and front always shows a "rotated" pattern? This would give six $90^\circ$-rotations and three $180^\circ$-rotations, $9=3^2$ in total. $$ \\ $$ Where do the missing $2^5\times 3^2$ come from?
  3. Is the reference given, online available?
EDIT
And to not make tehshrike sad again, here's the special question for $D4$:
What face sum is possible, so that the sum of the points on each side is the same, when you pile up 4 D4's to a pyramid (plus the octahedron mentioned by Henning) and how many representations, would such a pyramid have?
Thanks
draks ...
  • 18,755
  • related: http://math.stackexchange.com/q/154451/19341, splitted due to request here: http://math.stackexchange.com/a/229592/19341 – draks ... Nov 06 '12 at 07:27
    The point is, you really should ask one question per question. – Phira Nov 06 '12 at 08:25
    For the bonus question "(ok, 5 in the center for stability)", note that if you pile up four tetrahedra to form a larger tetrahedron, the open space in the middle is not in the shape of a tetrahedron, but is an octahedron. So putting a fifth tetrahedron in the middle is not going to stabilize the construction appreciably. – hmakholm left over Monica Nov 06 '12 at 11:59
  • @HenningMakholm thanks +1 for the correct stabilizer. – draks ... Nov 06 '12 at 13:02
Regarding your reference request:
The site of the magazine offers many of their articles online starting from 1997, so you cannot obtain the 1980 edition online (although you can likely buy a used print version).
Most good libraries in German-speaking countries do have this magazine, so, depending on your country, you could go directly go to the library, try to get an inter-library loan or contact friends in German-speaking countries to scan the appropriate pages for you.
Of course, the article will be in German.
Phira
  • 21,206
