I'm studying about uniform convergence of function sequences. I haven't been able to prove that
$$\lim_{n \to \infty} \left( \cos\left( \frac{x}{\sqrt{n}} \right) \right)^n=e^{-\frac{x^2}{2}}.$$
Can you help me, please?
    Hint: write $\left(\cos\left(\frac{x}{\sqrt{n}}\right)\right)^n=e^{n\ln\cos\left(\frac{x}{\sqrt{n}}\right)}$, and calculate the limit of the exponent. – Guy May 28 '17 at 16:59
  • @velutluna I corrected a little mistake. Well, $\cos\left(x\right)\sim 1-\frac{x^2}{2}$, and $\ln\left(1-x\right)\sim -x$. I think that should work – Guy May 28 '17 at 17:02
  • Welcome to Math.SE: In order to get the best possible answers, it is helpful if you say in what context you encountered the problem, and what your thoughts on it are; this will prevent people from telling you things you already know, and help them give their answers at the right level. Also, please try to make the title more descriptive. – projectilemotion May 28 '17 at 17:26
6 Answers6
$$\lim_{n\to\infty}\left(1-\frac{x^2}{2n}+o\left(\frac{1}{n}\right)\right)^n=e^{-\frac{x^2}{2}}$$
For detailed proof, see this Question about the proof of Central Limit Theorem
velut luna
  • 10,162
Compute the limit of the log, using Taylor's formula for the cosine at order $2$: $$n\ln\Bigl(\cos\dfrac x{\sqrt n}\Bigr)=n\ln\biggl(1-\dfrac{x^2}{2n}+o\Bigl(\frac1n\Bigr)\biggr)=n\biggl(-\dfrac{x^2}{2n}+o\Bigl(\frac1n\Bigr)\biggr)=-\dfrac{x^2}2+o(1).$$
Bernard
  • 179,256
The problem boils down to proving that $$ \lim_{n\to +\infty} n\log\cos\frac{x}{\sqrt{n}} = -\frac{x^2}{2}\tag{1} $$ and that can be achieved by squeezing. Both the functions $f(x)=\tan(x)$ and $g(x)=\frac{\tan x}{x}$ are convex on the interval $[0,1]$, hence it follows that $$ \forall x\in[0,1],\qquad x\leq \tan(x) \leq x+x^3 \tag{2}$$ and by integrating those inequalities over the interval $[0,z]$, for some $z\in[0,1]$, we get: $$ \forall z\in[0,1],\qquad \frac{z^2}{2}\leq -\log\cos(z) \leq \frac{z^2}{2}+\frac{z^4}{4}\tag{3} $$ so by replacing $z$ with $\frac{|x|}{\sqrt{n}}$ the claim follows by squeezing - for any $x\in\mathbb{R}$ the ratio $\frac{|x|}{\sqrt{n}}$ belongs to the interval $[0,1]$ for any $n$ large enough.
Jack D'Aurizio
  • 361,689
HINT:
$$\lim_{n \to \infty} \left( \cos\left( \frac{x}{\sqrt{n}} \right) \right)^n=\left(\lim_{n\to\infty}\left(1-\sin^2\dfrac x{\sqrt n}\right)^{-1/\sin^2\frac x{\sqrt n}}\right)^{\lim_{n\to\infty}\frac{-n\sin^2\frac x{\sqrt n}}2}$$
Now setting $x/\sqrt n=h,$ $$\lim_{n\to\infty}\dfrac{-n\sin^2\frac x{\sqrt n}}2=-\dfrac{x^2}2\lim_{h\to0}\dfrac{\sin^2h}{h^2}=?$$
  • Related: https://math.stackexchange.com/questions/2078615/find-lim-limits-x-to-0-frac-log-left-cos-x-rightx2-without-lhopita/2078623#2078623. We can use $$1-\cos2A=2\sin^2A$$ – lab bhattacharjee May 28 '17 at 17:08
  • Thank you for your help, but I don't understand why we can put the limit on the exponent. –  May 28 '17 at 17:50
Alternatively $$\lim _{ n\to \infty } \left( \cos \left( \frac { x }{ \sqrt { n } } \right) \right) ^{ n }=exp\left( \lim _{ n\to \infty } n\ln { \left( \cos \left( \frac { x }{ \sqrt { n } } \right) \right) } \right) =\\ =exp\left( \lim _{ n\to \infty } \frac { \ln { \left( \cos \left( \frac { x }{ \sqrt { n } } \right) \right) } }{ \frac { 1 }{ n } } \right) \overset { L'Hopital }{ = } exp\left( \lim _{ n\to \infty } \frac { -\frac { \sin { \left( \frac { x }{ \sqrt { n } } \right) } }{ \cos \left( \frac { x }{ \sqrt { n } } \right) } }{ -\frac { 1 }{ { n }^{ 2 } } } \left( -\frac { x }{ 2n\sqrt { n } } \right) \right) =\\ =exp\left( -\lim _{ n\to \infty } \tan { \left( \frac { x }{ \sqrt { n } } \right) } \frac { \sqrt { n } }{ 2x } { x }^{ 2 } \right) ={ e }^{ -\frac{x^2}{2} }$$
haqnatural
  • 22,026
Applying $\ln$ gives
$$\tag 1 n\cdot \frac{\ln \cos (x/\sqrt n)}{\cos (x/\sqrt n)-1}\cdot \frac{\cos (x/\sqrt n)-1}{(x/\sqrt n)^2}\cdot(x/\sqrt n)^2$$ $$= \frac{\ln \cos (x/\sqrt n)}{\cos (x/\sqrt n)-1}\cdot \frac{\cos (x/\sqrt n)-1}{(x/\sqrt n)^2}\cdot x^2.$$
Now let's use two well known limits
$$\tag 2\lim_{u\to 1} \frac{\ln u}{u-1} = 1,\,\,\lim_{u\to 0} \frac{\cos u - 1}{u^2} = -\frac{1}{2}.$$
As $n\to \infty,$ $x/\sqrt n \to 0$ and $\cos (x/\sqrt n) \to 1,$ so the limits in $(2)$ show the limit of $(1)$ is $1\cdot (-1/2)\cdot x^2 = -x^2/2.$ Exponentiating back shows the original limit is $e^{-x^2/2}.$
zhw.
  • 107,943
