I'm not really sure on how to go about solving this problem...
Consider the initial value problem.
$$y' (x) = \frac{1}{2}(-x + \sqrt{x^2 + 4y})$$ $$y(2) = -1$$
$a)$ Show that $y(x) = 1-x$ and $y(x) = -\frac{x^2}{4}$ are two solutions to the above IVP.
hm1912
  • 282
cisco
  • 369
You should just compute the derivative wrt $x$ of the suggested $y(x)$ and then plug into the first equation. Finally plugin the value $x=2$ and verify that the first equation holds.
Do the same for the other function $y(x)$.
Maczinga
  • 1,155
Consider $f(x)=1-x$; then $f'(x)=-1$, so $f'(2)=-1$. Also $$ \frac{1}{2}\bigl(-x+\sqrt{x^2+4f(x)}\,\bigr)= \frac{1}{2}\bigl(-x+\sqrt{x^2-4x+4}\,\bigr)= \frac{1}{2}\bigl(-x+|x-2|\,\bigr)= \begin{cases} -1 & \text{if $x\ge2$}\\ 1-x & \text{if $x<2$} \end{cases} $$ Thus the function $f$ is a solution of the problem only on the interval $[2,\infty)$. On $(-\infty,2]$ we have $$ \frac{1}{2}\bigl(-x+\sqrt{x^2+4f(x)}\,\bigr)=1-x\ne f'(x) $$
On the other hand, if $g(x)=-x^2/4$, $g'(x)=-x/2$ and $$ \frac{1}{2}\bigl(-x+\sqrt{x^2+4g(x)}\,\bigr)=-\frac{x}{2} $$ Thus the function $g$ is a solution over $\mathbb{R}$.
If you want a solution in a complete neighborhood of $2$, you have to choose the second one.
egreg
  • 244,946
