Problem. Let $A \subseteq X$. Let $f:A \to Y$ be continuous. Let $Y$ be Hausdorff. Prove that if $f$ is extended to a continuous function $g: \overline{A} \to Y$, then $g$ is uniquely determined by $f$.
My questions are,
Is the condition $Y$ is Hausdorff necessary? More specifically, is the there any counterexample to the following proposition?
Let $A \subseteq X$. Let $f:A \to Y$ be continuous. Let $Y$ be $T_1$-space. Prove that if $f$ is extended to a continuous function $g: \overline{A} \to Y$, then $g$ is uniquely determined by $f$.
If the answer to the above question is negative then is the converse of the problem true? More specifically, is the following proposition true?
Let $A \subseteq X$. Let $f:A \to Y$ be continuous. Suppose that $f$ is extended to a unique continuous function $g: \overline{A} \to Y$. Then $Y$ is Hausdorff.
