Why do we get $2$ solutions for a quadratic equation and $3$ solutions for a cubic equation and $4$ for biquadratic equation and so forth?
Fawad
  • 2,099
    "At most..." . A polynomial equation of degree $;n;$ has at most $;n;$ different solutions in some given field. This has to do with the fact that $;F[x];,;;F;$ a field, is an Euclidean domain and thus UFD and etc. – DonAntonio Oct 08 '16 at 15:19
  • @DonAntonioyou are wrong, solutions are not always different. An equation can have 3 solutions but same! – Fawad Oct 08 '16 at 15:21
  • Funny, I thought you were the one who asked. Never mind: I am not wrong (and apparently you didn't read all what I wrote or you didn't understand) , but if you decide I am then enjoy. – DonAntonio Oct 08 '16 at 15:22
  • Related (although not the same): http://math.stackexchange.com/questions/25822/how-to-prove-that-a-polynomial-of-degree-n-has-at-most-n-roots and http://math.stackexchange.com/questions/219115/how-do-i-prove-that-a-polynomial-fx-of-degree-n-has-at-most-n-roots – Martin Sleziak Oct 09 '16 at 07:22
This is only true if you allow the solutions to be complex. This is given by The Fundamental Theorem of Algebra, which states (quoted from the Wiki) that
"...every non-zero, single-variable, degree $n$ polynomial with complex coefficients has, counted with multiplicity, exactly $n$ roots."
  • So if any polynomial have degree of $π$ how many roots will it have? – Fawad Oct 08 '16 at 15:28
    @Ramanujan Then it isn't a polynomial, and the fundamental theorem doesn't hold. For it to be a polynomial, you must have non-negative integer exponents only. – Bobson Dugnutt Oct 08 '16 at 17:10
This is because of the factor theorem: if $r$ is a root of polynomial $P(x)$, then $P(x)$ must factor as $$P(x) = (x-r)Q(x),$$ where the degree of $Q$ is one less than the degree of $P$.
Then we have $P(x) =0$ if and only if $$(x-r)Q(r) =0,$$ which occurs when $x=r$ or when $x$ is a root of $Q$. So $P$ has at most one more root than $Q$, or exactly one more if you are willing to count multiple roots multiple times.
Since a 1st-degree polynomial evidently has 1 root, an $n$th-degree polynomial has $n$ roots (or "at most $n$" if you don't count the multiple roots separately.)
MJD
  • 67,568
  • 43
  • 308
  • 617
