Suppose you have a rational conic $ax^2+bxy+cy^2+dx+ey+f=0$. There is a theorem that states if a conic has 1 rational solution it has infinitely many rational solutions. How can you prove this geometrically?
You had best typeset in the thing for which you want solutions. Also identify what particular theorem of Legendre is involved. – Will Jagy Jun 01 '16 at 23:47
The same equation reduces to Pell's equation. There solution is always there. http://math.stackexchange.com/questions/794510/curves-triangular-numbers – individ Jun 02 '16 at 12:34
A generic line intersects a conic in $2$ points.
If the conic and the line are rational (given by rational coefficients), then the set consisting of those two points is invariant by $\Bbb Q$-automorphisms, so either each point is rational, either they are defined over a quadratic extension of $\Bbb Q$ and the automorphism of that extension swaps the two intersection points.
If you have a rational point $P$ on the conic, then the rational lines going through it will intersect the rational conic at another rational point (possibly $P$ itself if the line is tangent at $P$ to the conic)
Moreover, two different lines going through $P$ can only intersect at $P$, so the lines that are not tangent to the conic at $P$ give you distinct points on the conic.
This actually gives you a birational map between $\Bbb P^1$ and the conic.
- 51,119
