-1
I need help with finding the area of the largest rectangle in an ellipse from $y^2 + (x^2)/4 = 1$.
I got it to y = $\sqrt{ 1 - (x^2)/4}$ but then I don't really know what to do, please help.
Chill2Macht
  • 22,055
  • 10
  • 67
  • 178
Tobias
  • 21
I guess the area is defined as $x\times y$. So far, you got $y=\sqrt{1-x^2/4}$, therefore
$$A(x)=x\times\sqrt{1-x^2/4} \quad \text{for}\quad -2 \leq x \leq 2$$
Negative values do not make sense, so these might be ruled out. Also, the area would be $0$ for $x=2$ and $x=0$, so $0 < x < 2$.
Now you have to find the maximum of this function by differentiating.
$$\frac{dA}{dx}=-\frac{x^2-2}{2\sqrt{1-x^2/4}}$$
The slope at the highest point is $0$, so
$$0=-\frac{x^2-2}{2\sqrt{1-x^2/4}}$$
A fraction is only $0$, if the numerator is $0$:
$$0=x^2-2$$
Finally, $$x = \sqrt{2}$$
With this solution, you can find the final maximum area of the rectangle.
qwertz
  • 219
  • Where did x^2 - 2 come from? – Tobias May 22 '16 at 13:14
  • @Tobias By differentiating $A(x)$ and simplifying the result (in this case there are many variations that may not look the same). I have omitted the step by step solution, because it would take up too much space. – qwertz May 22 '16 at 18:36
  • That makes sense! Thank you for the help. I think I have solved it now. – Tobias May 23 '16 at 11:23
