If you want to find the generators for the product of ideals, do you simply take all possible products of the generators in the ideals. For example, let $R$ be a ring and let $I = (a,b)$ and $J = (c,d)$. Then we have
\begin{equation*} \begin{aligned} IJ &= \{(ax + by)(cw + dz) : w,x,y,z \in R\} \\ &= \{ac(xw) + ad(xz) + bc(yw) + bd(yz) : w,x,y,z \in R\}. \end{aligned} \end{equation*}
We see that $IJ$ contains all multiples of $ac,ad,bc,bd$ and their sums. So then $IJ = (ac,ad,bc,bd)$. Is this true in general? Thanks!
Does this method work regardless of the number of ideals and generators is what I mean.
Yes, it does. Let $I = (a_1, \ldots, a_m)$ and $J = (b_1, \ldots, b_n)$ be left ideals in a ring commutative ring $R$. Then $$IJ = \{(x_1a_1 + x_1a_2 + \ldots + x_ma_m)(y_1b_1 + y_2b_2 + \ldots + y_nb_n) \}$$ and clearly $a_ib_j \in IJ$ for all $1 \le i \le m$ and $1 \le j \le n$. Conversely, every element in $IJ \setminus \{0\}$ is of the form $\sum_{i,j} z_{i,j}a_i b_j$.
An easy induction on the number of factors yields the result for $I_1I_2 \ldots I_n$ as well.
However, in a non-commutative ring we only get $(a_1, \ldots, a_m)(b_1, \ldots, b_n) \supseteq (a_ib_j)_{i,j}$.
As an example consider the ring of $2 \times 2$ matrices with integer coefficients. Then $$ \left( \begin{matrix} 1 & 0 \\ 0 & 0 \end{matrix} \right) \left( \begin{matrix} 0 & 0 \\ 1 & 1 \end{matrix} \right) = \left( \begin{matrix} 0 & 0 \\ 0 & 0 \end{matrix} \right) $$
and thus $ \left( \left( \begin{matrix} 1 & 0 \\ 0 & 0 \end{matrix} \right) \left( \begin{matrix} 0 & 0 \\ 1 & 1 \end{matrix} \right) \right) = (0) $, but $$ \left( \begin{matrix} 1 & 0 \\ 0 & 0 \end{matrix} \right)\left( \begin{matrix} 1 & 1 \\ 1 & 1 \end{matrix} \right) \left( \begin{matrix} 0 & 0 \\ 1 & 1 \end{matrix} \right) = \left( \begin{matrix} 1 & 1 \\ 0 & 0 \end{matrix} \right) $$ demonstrates $ \left( \left( \begin{matrix} 1 & 0 \\ 0 & 0 \end{matrix} \right), \left( \begin{matrix} 0 & 0 \\ 1 & 1 \end{matrix} \right) \right) \neq (0)$.
Stefan Mesken
  • 16,852
  • 28
  • 48
  • this is a pedantic point, but nonetheless: technically $IJ$ is not the set of elements of that form, but actually the ideal generated by the set of elements of that form. for instance, consider $I=(x,y)$ and $J=(z,w)$ in a polynomial ring $F[x,y,z,w]$. then, for instance, $xz+yw$ is an element of $IJ$, but it cannot be written as a product of an element from $I$ and an element from $J$. nonetheless your argument still works, since showing an ideal lies in another ideal is equivalent to showing that a set of its generators does. (+1) – Atticus Stonestrom Mar 18 '21 at 16:54
