This is the question:
Problem B.1 Two cities - Tel-Aviv, Israel and SanDiego, CA - have the same latitude 32 ◦ N, but, different longitudes: Tel-Aviv is 34 ◦ E and San-Diego is 117 ◦ W. What is the maximal distance between the great circle arc and the 32 ◦ latitude line? By how much the path along the great circle (geodesic) arc will be shorter than the path along the latitude line? Hint: Spherical triangles (on a sphere with radius 1) satisfy a spherical law of cosines $$\cos(c)=\cos(a)\cos(b)+\sin(a)\sin(b)\cos(C)$$.
I don't want the solution. My main problem is I don't know where to begin and where I want to get to. Could you help me with figuring out how to get through such problems?
Euler-Lagrange equation: $$\frac{d}{dx}L_{y'}-L_y=0$$ while $$I[y(x)]=\int_{x_0}^{x_1}L(y',y,x)dx$$
Full description (as our lecturer assures us) is right here, page 2.
Avitus
  • 14,348
  • 31
  • 52
  • Can you write the Euler-Lagrange equations for the length function? – Alexander Gruber Apr 23 '12 at 01:09
  • @AlexanderNikolasGruber I had edited the post. – Michael Sazonov Apr 23 '12 at 01:56
  • Is a 'latitude line' a straight line between the two cities? And if so, why bother with Euler Lagrange to solve the problem? – copper.hat Apr 23 '12 at 04:11
  • @copper.hat Yes. But the question is what is the maximal distance between geodesic and latitude lines. – Michael Sazonov Apr 23 '12 at 04:37
  • If I understand correctly, the geodesic, the latitude line and center of the earth all lie on the same 2-dim. plane. The end points of the geodesic define an angle $\alpha$ in this plane, the maximum separation will occur at $\frac{\alpha}{2}$, etc, etc... – copper.hat Apr 23 '12 at 06:03
  • @copper.hat The geodesic lies on the same plane as earth center, but the latitude slices the sphere parallel to equator. Logically, it is clear that the distance is maximal at $\frac{\alpha}{2}$, but it needs to be proved. If I'm not that clear - you could check out the link in the post. There's the full explanation. – Michael Sazonov Apr 23 '12 at 06:13
