I am reading a paper and trying to understand a calculation and all of a sudden I bump into the following term:
$D^2_y p(t,y(t,x))(\partial_t y(t,x),y^\epsilon(t,x))$
where $p$ is a scalar field (pressure), $D_y^2p$ is the Hessian matrix of $p$ wrt the spacial variables, $y$ and $y^\epsilon$ are vector fields, and $\partial_t y$ is the partial derivative of $y$ wrt $t$.
Now, for understanding the calculations I am assuming that the brackets are notation for:
$\left(D^2_y p(t,y(t,x))\cdot\partial_t y(t,x) \right) \cdot y^\epsilon(t,x))$
This makes sense in many ways, specially since this term ought to be a scalar.
I think I get a confirmation further on in the paper where it is stated that
$D^2_y p (t,y) \left((v \cdot \nabla )y, y^\epsilon-y \right)=\sum_{ijk} \partial^2_{ij}p(t,y) \: v_k \: \partial_k y_i \: (y^\epsilon-y)_j$,
here $v$ is a (velocity) vector field.
My question is: has anybody seen something like this before? Maybe its a notation physicists use. I have never seen it before and I couldn't find it anywhere. So far I couldn't think of any other interpretation (nor I think any other is possible). However, I am having trouble following the author's calculations and maybe this could be the source of my problem.
By the way, the paper I am referring to is the following one: http://math1.unice.fr/~brenier/fichiers.ps.pageperso/cms-semigeo-xz-rigorous.pdf
Thank you very much in advance!
chango
  • 2,128
  • What paper? $\phantom{}$ – J. M. ain't a mathematician Apr 19 '12 at 15:09
  • This one: http://math1.unice.fr/~brenier/fichiers.ps.pageperso/cms-semigeo-xz-rigorous.pdf the first term is on page 4. – chango Apr 19 '12 at 15:13
    Please include that link into your question. – J. M. ain't a mathematician Apr 19 '12 at 15:16
    I think it may help to include the specific equation (as I believe you made a typo) (page 4):
    $$I_{3}=-\int_{D} [(\partial_{t} \nabla p^{\ast} )(t,y(t,x)) \cdot y^{\epsilon}(t,x) +(D_{y}^{2}p^{\ast})(t,y(t,x))(\partial_{t}y(t,x),y^{\epsilon}(t,x)) ]dx$$ Note that: $p$ is an implicit function defined $p=p(t,x)$ for the pressure field, $y=y(t,x)\in R^{d}$ is the "vector-valued forcing term", $D$ is a smooth bounded domain in $R^{d}$ $(d=2,3)$, and $\epsilon$ and $\alpha$ (both greater than $0$) are scaling factors.
    I believe $\partial$ and $\nabla$ have traditional definitions in this context.
    – 000 Apr 19 '12 at 16:07
    There is also two other integral terms in $I_{3}$, which makes the full definition of $I_{3}$ read:
    $$I_{3}=-\int_{D} [(\partial_{t} \nabla p^{\ast} )(t,y(t,x)) \cdot y^{\epsilon} (t,x)+(D_{y}^{2}p^{\ast})(t,y(t,x))(\partial_{t}y(t,x),y^{\epsilon} (t,x)) ]dx -\int_{D}(\nabla p^{\ast})(t,y(t,x)) \cdot G(x,y^{\epsilon}(t,x)) dx+I_{5}$$
    $$I_{5}=\int_{D} x \cdot (v^{\epsilon}(t,x) \cdot \nabla)y^{\epsilon}(t,x) dx$$
    $G(x,y)$ is a given smooth vector-valued source term $D \times R^{d} \to R^{d}$ and $v=v(t,x)\in R^{d}$ is the velocity field, and $x \in D$.
    – 000 Apr 19 '12 at 16:14
  • Yes, well, in fact I replaced the Legendre transform $p^*$ by $p$ on purpose just because I think it doesn't make any difference in the context of my question, and I didn't want it to look overcomplicated. Thanks for pointing that out anyway. – chango Apr 19 '12 at 16:15
    I wasn't aware if it made any difference or not--I do not understand these equations. However, I provided the full thing in hopes of making things more easily referenced. – 000 Apr 19 '12 at 16:19
I believe the Hessian is being treated as a bilinear form; see for instance here, here and here.
If so, your interpretation in terms of products is correct (though it's slightly unusual to denote the product of the matrix $D^2_yp$ and the vector $\partial_t y$ with a dot).
joriki
  • 242,601
