18
Prove that $\left(1+\dfrac{1}{1^3}\right)\left(1+\dfrac{1}{2^3}\right)\ldots\left(1+\dfrac{1}{n^3}\right)<3$ for all positive integers $n$
This problem is copied from Math Olympiad Treasures by Titu Andreescu and Bogdan Enescu.They start by stating that induction wouldn't directly work here since the right hand side stays constant while the left increases.They get rid of this problem by strengthening the hypothesis.$$\left(1+\dfrac{1}{1^3}\right)\left(1+\dfrac{1}{2^3}\right)\ldots\left(1+\dfrac{1}{n^3}\right)\le3-\dfrac{1}{n}$$ and then proceed by induction.
The problem is that I can't find a motivation for the above change.I mean,we could have subtracted a lot of things from the RHS but what should nudge us to try $\dfrac{1}{n}$?The rest of the proof is quite standard,but I can't see how I am supposed to have thought of it.Is it just experience?Or is it a standard technique?A little guidance and motivation will be appreciated.
Angelo
  • 13,952
rah4927
  • 3,984
    It won't be Olympiad problem if you can easily find the trick. :p –  Nov 06 '14 at 12:50
  • @frank000,of course it won't.But a problem can't be solved without motivation,can it? – rah4927 Nov 06 '14 at 12:52
    The "subtract something and prove a stronger inequality" is standard. Then you say you want to prove $p_n < 3 - a_n$, and check what (preferably simple) $a_n$ would work for the induction step. That won't always work (at least not well), but often does. – Daniel Fischer Nov 06 '14 at 12:52
    Usually you can have insights by looking at the first terms. You take $n=1,2,3,4$... and try to see if you can deduce something out of it. – Martigan Nov 06 '14 at 12:52
  • 16
    I hope that the authors also provided the solution $$\prod_{k=1}^n \left( 1 + \frac{1}{k^3}\right) = 2 \prod_{k=2}^n \frac{k^3+1}{k^3} < 2\prod_{k=2}^n \frac{k^3+1}{k^3-1} < 2\prod_{k=2}^\infty \frac{k^3+1}{k^3-1} = 3$$ with the telescoping product. – Daniel Fischer Nov 06 '14 at 12:58
  • @DanielFischer,nope,the chapter was on induction.Nice proof though. – rah4927 Nov 06 '14 at 13:03
    How does it telescope exactly? I don't really see it since all terms are different.. – mvggz Nov 06 '14 at 13:10
  • @mvggz: Yeah, same feeling for me. But when you factor $k^3+1$ and $k^3-1$, everything is just magical. – Quang Hoang Nov 06 '14 at 13:18
  • It appears to me that the telescope part is $k+1\over k-1$ with remaining fraction $k^2-k+1\over k^2+k+1$. But then plugging $k+1$ into $k^2-k+1$ yields $k^2+k+1$, so that part telescopes too, just at a different rate. – abiessu Nov 06 '14 at 13:19
  • I see, there is a - that gives the telescoping.. That's smart :) – mvggz Nov 06 '14 at 13:20
  • From another question, I recall that the similar technique applies to show $(1+1/n)^n<3$. – Quang Hoang Nov 06 '14 at 13:34
  • @DanielFischer, why $\displaystyle\prod\limits_{k=2}^{\infty}\dfrac{k^3+1}{k^3-1}=\dfrac32;?;$ How are you using the telescoping product ? Please, explain it to me because I cannot understand it. – Angelo May 25 '21 at 19:05
6 Answers6
8
As mentioned in the comments, the trick to subtract something (or multiply with something $< 1$) and prove a stronger inequality than required is standard.
So we want to prove
$$p_n \leqslant 3- a_n$$
for a preferably simple $a_n > 0$ by induction. For the induction start, we here need $a_1 \leqslant 1$. For the induction step to work, we need
$$\left( 1 + \frac{1}{(n+1)^3}\right)(3-a_n) \leqslant 3 - a_{n+1}.$$
Multiplying out and cancelling the $3$, we get
$$-a_n + \frac{3}{(n+1)^3} - \frac{a_n}{(n+1)^3} \leqslant -a_{n+1}.$$
Throwing away the $\frac{a_n}{(n+1)^3}$ term to simplify the calculations, we see that
$$\frac{3}{(n+1)^3} \leqslant a_n - a_{n+1}$$
is sufficient. With the ansatz $a_n = \frac{c}{n^k}$, we have
$$a_n - a_{n+1} = c\frac{(n+1)^k-n^k}{n^k(n+1)^k} \approx c\frac{k}{n(n+1)^k},$$
so here we need $k \leqslant 2$. But $a_1 \leqslant 1$ requires $c\leqslant 1$, and hence $k = 2$ doesn't work. So we try $k = 1$ and find $a_n = \frac{1}{n}$ works.
Daniel Fischer
  • 211,575
  • Thank you very very much for this answer.Do you mind if I use this answer(with all credits to you) somewhere else?It would help some other people on Brilliant.org if I could.And thanks again for this answer. – rah4927 Nov 07 '14 at 07:51
  • No, I don't mind at all. Go ahead and share. – Daniel Fischer Nov 07 '14 at 12:52
Since: $$ 1+\frac{1}{k^3}=\left(1+\frac{1}{k}\right)\left(1-\frac{1}{k}+\frac{1}{k^2}\right) = \left(1-\frac{1}{k^2}\right)\left(1+\frac{1}{k(k-1)}\right) $$ and: $$ \prod_{k=2}^{+\infty}\left(1-\frac{1}{k^2}\right)=\frac{1}{2} $$ we have: $$ \prod_{k=1}^{+\infty}\left(1+\frac{1}{k^3}\right)=\prod_{k=2}^{+\infty}\left(1+\frac{1}{k(k-1)}\right)=\prod_{k=1}^{+\infty}\left(1+\frac{1}{k(k+1)}\right),$$ but since $1+x < e^x$ and $\frac{1}{k(k+1)}=\frac{1}{k}-\frac{1}{k+1}$ it follows that: $$ \prod_{k=1}^{+\infty}\left(1+\frac{1}{k^3}\right)<\exp\sum_{k=1}^{+\infty}\frac{1}{k(k+1)}=e<3.$$ With the same trick we can also prove the stronger: $$ \prod_{k=1}^{+\infty}\left(1+\frac{1}{k^3}\right) < \frac{3}{2}\sqrt{e} <\frac{5}{2}.$$
Jack D'Aurizio
  • 361,689
If we need to prove the strong inequality and proving the weak inequalities for the simplest to imagine values is easy...
\begin{align*} \left(3-\frac1n\right)\left(1+\frac1{(n+1)^3}\right) &= 3+\frac3{(n+1)^3}-\frac1n-\frac1{n(n+1)^3}\\ &=3+\frac{3n-(n+1)^3-1}{n(n+1)^3}\\ &=3+\frac{-n^3-3n^2-2}{n(n+1)^3}\\ &=3+\frac{-1}{n+1} \frac{n^3+3n^2+2}{n^3+2n^2+n}\\ &\leq3-\frac1{n+1} \end{align*}
Just for the fun of it, I tried to use this (I've answered about it not long ago :) ) :
$ [x_1*...*x_n]^{\frac{1}{n}} \leq \frac{x_1+...+x_n}{n} $
Now set: $ x_k = 1 + \frac{1}{k^3} $; $C_n = \sum_{k=2}^{n} \frac{1}{k^3} $
You get : $x_1*...*x_n = 2*(1+\frac{1}{2^3})...(1 +\frac{1}{n^3}) \leq 2*(\frac{x_2+...+x_n}{n-1})^{n-1} = 2*(\frac{n-1+C_n}{n-1})^{n-1} $
=> $ 2*(1+\frac{1}{2^3})...(1 +\frac{1}{n^3}) \leq 2*(1+\frac{1}{n-1}*C_n)^{n-1} $
Now $C_n \rightarrow C $, with $C_n \leq C $; and $ (1+\frac{C_n}{n-1})^{n-1} \leq e^{C_n} \leq e^C$
Hence you get:$ 2*(1+\frac{1}{2^3})...(1 +\frac{1}{n^3}) \leq 2*e^C = e^{ln(2) + C}$
Now we want to see if : $ln(2) + C \leq ln(3) $ Numerically this is true since $ln(\frac{3}{2})$ ~0,4~$2*C$. Not very difficult to prove.
It's not really what was asked but I thought it was interesting.
mvggz
  • 1,985
Just to give a different approach (similar to Jack D'Aurizio's), note that, for $k\gt1$, we have
$$\ln\left(1+{1\over k^3}\right)\lt{1\over k^3}\lt{1\over k^3-k}={1\over2}\left({1\over k-1}-{2\over k}+{1\over k+1}\right)$$
It follows that
$$\begin{align} \ln\left(\left(1+{1\over1^3}\right)\left(1+{1\over2^3}\right)\left(1+{1\over3^3}\right)\cdots\right) &=\ln2+\sum_{k=2}^\infty\ln\left(1+{1\over k^3}\right)\\ &\lt\ln2+{1\over2}\sum_{k=2}^\infty\left({1\over k-1}-{2\over k}+{1\over k+1}\right)\\ &=\ln2+{1\over2}\left({1\over2-1}-{2\over2}+{1\over3-1} \right)\quad\text{(after telescoping)}\\ &=\ln2+{1\over4}\\ &={1\over4}\ln(16e)\\ &\lt{1\over4}\ln81\\ &=\ln3 \end{align}$$
Barry Cipra
  • 81,321
When n is smaller than 3, it is easy to compute it.
When n is greater or equal to 3:
$$ \begin{aligned} \ln \left[(1+\frac{1}{1^3})(1+\frac{1}{2^3})...(1+\frac{1}{n^3}) \right] &= \ln 2+ \sum_{i=2}^{n}\ln(1+\frac{1}{i^3}) \\ &<\ln 2 +\sum_{i=2}^{n}\frac{1}{i^3} \\ &<\ln 2+\frac{1}{8}+\int_2^n \frac{1}{x^3} dx \\ &=\ln 2+\frac{1}{8}+\left[ -\frac{1}{2x^2} \right]_2^n \\ &=\ln 2+\frac{1}{4}-\frac{1}{2n^2} \\ &<\ln 2 + \frac{1}{4}<1<\ln 3 \end{aligned} $$
