30
I am trying to understand this paper and am unsure of what bi-linear upsampling is. Can anyone explain this at a high-level?
Ethan
  • 1,657
  • 9
  • 25
  • 39
JGG
  • 523
In the context of image processing, upsampling is a technique for increasing the size of an image.
For example, say you have an image with a height and width of $64$ pixels each (totaling $64 \times 64 = 4096$ pixels). You want to resize this image to a height and width of 256 pixels (totaling $256 \times 256 = 65536$ pixels). In the new, larger image you only know the value of $1$ out of every $16$ pixels. How are you going to calculate the values for the rest?
Well, the methods that do that for you are called upsampling techniques. The most common are:
  • Nearest-Neighbor: Copies the value from the nearest pixel.
  • Bilinear: Uses all nearby pixels to calculate the pixel's value, using linear interpolations.
  • Bicubic: Again uses all nearby pixels to calculate the pixel's values, through polynomial interpolations. Usually produces a smoother surface than the previous techniques, but its harder to compute.
  • Other more complex resampling algorithms, e.g. Lanczos.
An article explaining the differences among image resampling techniques can be found here.
Djib2011
  • 8,068
  • 28
  • 39
