I used tensorflow to recognize text from natural images by using convolutional neural network; there is no specific number of characters in the text. To make a successful training I should convert the categorical labels into binary using one-hot encoding. So, for each label, I used integer encoding for each character and stored them in one numpy array in order to create TFRecords. For example:
alphabet = 'abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ '
TrainLabel  = ["CNN in Tensorflow"]
# define a mapping of chars to integers
char_to_int = dict((c, i) for i, c in enumerate(alphabet))
integer_encoded = [char_to_int[char] for char in TrainLabel[0]]
if (len(TrainLabel[0])) < 51:
    for j in xrange(51- (len(TrainLabel[0]))):
        integer_encoded.append(52)
# one hot encode
onehot_encoded = []
for value in integer_encoded:
    letter = [0 for _ in range(len(alphabet))]
    letter[value] = 1
    onehot_encoded.append(letter)
label = np.array(onehot_encoded, np.float32)
51 is the maximum number of character in the text, so if the text has less than 51 characters, pad it to 51 characters with spaces.
If we print the label, it will be like this::
array([[ 0.,  0.,  0., ...,  0.,  0.,  0.],
       [ 0.,  0.,  0., ...,  0.,  0.,  1.],
       [ 0.,  0.,  0., ...,  0.,  0.,  1.]], dtype=float32)
after creating the batch queue, the label has shape [batch_size, 2703]. 2703 is come from 51*53 which 53 is the number of classes
My problem is in loss function:: the label shape in tf.nn.sparse_softmax_cross_entropy_with_logits() must be [batch_size], but the label that I used here has this shape [batch_size, 53] because I used one-hot encoding?
How can I deal with that??
This is the problem::
(labels_static_shape.ndims, logits.get_shape().ndims)) ValueError: Rank mismatch: Rank of labels (received 2) should equal rank of logits minus 1 (received 2).
Stephen Rauch
  • 1,831
  • 11
  • 23
  • 34
AB_
  • 185
Since your data are already in a one-hot encoding, you can use tf.nn.softmax_cross_entropy_with_logits(), which expects an input of shape [batch_size, num_classes] for the labels.
(The tf.nn.sparse_softmax_cross_entropy_with_logits() op expects the labels as a batch of integers, where each integer corresponds to the class ID for each example.)
mrry
  • 136
If you are using Tf 2.0 then using tf.keras.losses.categoricalcrossentropy should solve this
model.compile(optimizer='sgd', loss=tf.keras.losses.CategoricalCrossentropy(from_logits=False), metrics=['accuracy'])
Vivek
  • 87
