14
The 3-Partition problem asks whether a set of $3n$ integers can be partitioned into $n$ sets of three integers such that each set sums up to some given integer $B$. The Balanced Partition problem asks whether $2n$ integers can be partitioned into two equal cardinality sets such that both sets have the same sum. Both problems are known to be NP-complete. However, 3-Partition is strongly NP-complete. I haven't seen in the literature any reduction from 3-Partition to Balanced Partition.
I'm looking for (simple) reduction from the 3-Partition to the Balanced Partition problem.
Ran G.
  • 20,884
  • 61
  • 117
Mohammad Al-Turkistany
  • 4,477
  • 28
  • 37
There are thousands of NP-complete problems in the literature, and most pairs do not have explicit reductions. Since polynomial-time many-one reductions compose, it suffices for researchers to stop when the graph of published reductions is strongly connected, making research into NP-completeness a much more scalable activity.
Although I really don't see the point, I'll humor you by giving a reasonably simple reduction from 3-PARTITION to BALANCED PARTITION, with a few hints about how the proof of correctness goes.
Let the input to the reduction be $x_1, \ldots, x_{3n}, B \in \mathbb Z$, an instance of 3-PARTITION. Verify that $\sum_{i\in[3n]} x_i = nB$. Let $\beta$ be a large number to be chosen later. For every $i \in [3n]$ and every $j \in [n]$, output two numbers $$x_i \beta^j + \beta^{n+j} + \beta^{2n+i} + \beta^{(i+4)n+j}\\ \beta^{(i+4)n+j}.$$ Intuitively, the first number means that $x_i$ is assigned to 3-partition $j$, and the second number means the opposite. The $x_i \beta^j$ term is used to track the sum of 3-partition $j$. The $\beta^{n+j}$ term is used to track the cardinality of 3-partition $j$. The $\beta^{2n+i}$ term is used to ensure that each $x_i$ is assigned exactly once. The $\beta^{(i+4)n+j}$ term is used to force these numbers into different balanced partitions.
Output two more numbers $$1 + \sum_{j\in[n]} \Bigl((n-2)B\beta^j + (3n-6)\beta^{n+j}\Bigr) + \sum_{i\in[3n]} (n-2)\beta^{2n+i}\\ 1.$$ The first number identifies its balanced partition as “true”, and the other, as “false”. The $1$ term is used to force these numbers into different balanced partitions. The other terms make up the difference between the sum of a 3-partition and the sum of its complement and the size of a 3-partition and the size of its complement and the number of times $x_i$ is assigned.
$\beta$ should be chosen large enough to ensure that “overflow” cannot occur.
Herm
  • 156
This paper, Fast Balanced Partitioning is Hard Even on Grids and Trees, by Andreas Emil Feldmann contains what you want! Good luck!
We will set up a general framework for a reduction from 3-PARTITION to different graph classes. This will be achieved by identifying some structural properties that a graph constructed from a 3-PARTITION instance has to fulfil, in order to show the hardness of the $k$-BALANCED PARTITIONING problem ...
Merbs
  • 1,223
  • 11
  • 21
Daniel
  • 9
