29
Every undecidable problem that I know of falls into one of the following categories:
  1. Problems that are undecidable because of diagonalization (indirect self-reference). These problems, like the halting problem, are undecidable because you could use a purported decider for the language to construct a TM whose behavior leads to a contradiction. You could also lump many undecidable problems about Kolmogorov complexity into this camp.
  2. Problems that are undecidable due to direct self-reference. For example, the universal language can be shown to be undecidable for the following reason: if it were decidable, then it would be possible to use Kleene's recursion theorem to build a TM that gets its own encoding, ask whether it will accept its own input, then does the opposite.
  3. Problems that are undecidable due to reductions from existing undecidable problems. Good examples here include the Post Correspondence Problem (reduction from the halting problem) and the Entscheidungsproblem.
When I teach computability theory to my students, many students pick up on this as well and often ask me if there are any problems we can prove are undecidable without ultimately tracing back to some kind of self-reference trickery. I can prove nonconstructively that there are infinitely many undecidable problems by a simple cardinality argument relating the number of TMs to the number of languages, but this doesn't give a specific example of an undecidable language.
Are there any languages known to be undecidable for reasons that aren't listed above? If so, what are they and what techniques were used to show their undecidability?
Raphael
  • 73,212
  • 30
  • 182
  • 400
templatetypedef
  • 9,302
  • 32
  • 62
Yes, there are such proofs. They are based on the Low Basis Theorem.
See this answer to Are there any proofs the undecidability of the halting problem that does not depend on self-referencing or diagonalization? question on cstheory for more.
Kaveh
  • 22,661
  • 53
  • 113
This is a really interesting question and I also had this question before when I learn computability theory. Here I give an alternative angle to view this question. In the following paragraphs I assume that the formal system that I use is first-order logic.
If you can prove that a problem P is undecidable, then you have at least one “proof” showing that “P is undecidable”. Since the set of all possible proofs is countable, we can conclude that the set of undecidable problems that you can formally prove the undecidability is also countable. But the set of all undecidable problems is uncountable, which means most undecidable problems cannot be proved to be undecidable at all.
On the other hand, if you can show a countably infinite set of undecidable problems where each problem’s undecidability can be proved via self-reference, you can at least show that the cardinality of the set of “provably undecidable problems” and the cardinality of the set of “undecidable problems provable by self-reference” are the same. This might not be an interesting result, but if we can go one step further and prove something like “all/almost all provably undecidable problems could be proved to be undecidable by self-reference”, I think that will be interesting enough.
Regarding specific proof techniques, I don’t know non-self-reference techniques for proving undecidability but I can make an informal argument stating that those techniques may not exist for certain undecidable problems. In program analysis, which is a research area trying to design (incomplete) analyzers to inform programs’ non-trivial properties, according to Rice’s theorem, non-trivial extensional properties of programs are undecidable. For such undecidable problems, different program analyzers give different “precisions” (e.g. the number of programs that they can precisely analyze). This might imply that the undecidability indeed depends on the analyzer itself because for a specific program, whether its property could be precisely analyzed via a given analyzer depends on the analyzer itself. As a result, I feel that a proof showing the undecidability of program analysis (the non-existence of complete program analyzers) tends to somehow mention the analyzer itself, which constitutes a “self-reference”. Of course I’m talking about the prove-by-contradiction route “assuming that a complete analyzer exists”.
NaN
this is not exactly an affirmative answer, but an attempt at something nearby to what is asked for via a creative angle. there are quite a few problems in physics now that are "far distant" from mathematical/ theoretical formulations of undecidability, and they seem increasingly "remote" from and "bear little resemblance to" the original formulations involving the halting problem etc.; of course they use the halting problem at the root but the chains of reasoning have become increasingly distant and also have a strong "applied" aspect/ nature. unfortunately there do not seem to be any great surveys in this area yet. a recent problem that was "surprisingly" proven undecidable in physics that has attracted a lot of attention:
The spectral gap—the energy difference between the ground state and first excited state of a system—is central to quantum many-body physics. Many challenging open problems, such as the Haldane conjecture, the question of the existence of gapped topological spin liquid phases, and the Yang–Mills gap conjecture, concern spectral gaps. These and other problems are particular cases of the general spectral gap problem: given the Hamiltonian of a quantum many-body system, is it gapped or gapless? Here we prove that this is an undecidable problem. Specifically, we construct families of quantum spin systems on a two-dimensional lattice with translationally invariant, nearest-neighbour interactions, for which the spectral gap problem is undecidable. This result extends to undecidability of other low-energy properties, such as the existence of algebraically decaying ground-state correlations.
what you seem to be observing in the question is that (informally) undecidability proofs all have a certain "self-referential" structure, and this has been formally proven in even more advanced mathematics, such that both the Turing halting problem and Godels theorem can be seen as instances of the same underlying phenomenon. see eg:
The halting theorem, Cantor's theorem (the non-isomorphism of a set and its powerset), and Goedel's incompleteness theorem are all instances of the Lawvere fixed point theorem, which says that for any cartesian closed category, if there is an epimorphic map e:A→(A⇒B) then every f:B→B has a fixed point.
there is also a long meditation on this theme of the (intrinsic?) interconnectedness of self-referentiality and undecidability in the books by Hofstadter. another area where undecidability results are common and were initially somewhat "surprising" is with fractal phenomena. the crosscutting appearance/ significance of undecidable phenomena across nature is nearly a recognized physical principle at this point, first observed by Wolfram as "principle of computational equivalence".
vzn
  • 11,162
  • 28
  • 52
