I've recently heard the claim that wide block ciphers avoid birthday bound problems. Trying to figure out what exactly "wide block encryption" is, a quick search turned up this paper which is trying to do the following:
The focus of this paper is how to use a standard block cipher as a component to build a ”wide” block cipher, or, in other words, to build a secure PRP from another PRP operating on a smaller domain.
Also stating that
The size of the wide block cipher is l=n∗m bits.
It specifically mentions IEEE P1619-2 (Wikipedia). But that standard seems to be paywalled. From the description on Wikipedia it sounds like it is related to disk encryption but that is not a real definition. It might just be a block cipher with a bigger block size but that seems pretty vague.
Could somebody please tell me what a wide block cipher is and why it avoids the birthday bound?
Elias
  • 4,933
  • 16
  • 32
I don't think the term "wide block cipher" has a hard definition beyond
has a larger block size than the current standard algorithm(s)
which right now in most cases would equal to
has a block size larger than 128 bit
because AES is our current reference standard.
Now the thing with block ciphers is that they are are pseudo-random permutations and as such you can distinguish them from pseudo-random functions because you will see a collision with the latter at the birthday where you won't find that with PRPs. This can be important in scenarios where you need to generate a lot of random numbers mostly and even then I don't think the different characteristic would be exploitable in most cases.
To see how PRPs can be distinguished, assume as an example that you run CTR-mode with a PRF and a PRP, both with $n$-bit output length. You will now find that a collision in the CTR keystream occurs with the PRF at about $2^{n/2}$ invocations whereas this won't happen until after you wrap-around with the PRP.
Another application of wide block ciphers is in full-disk encryption where you can encrypt larger blocks implying that single bit-flips will destroy larger regions of plaintext thus being (hopefully) more notice-able.
The last somewhat popular application of wide block ciphers is as part of hashing functions. Imagine your average block cipher $E:\{0,1\}^k\times \{0,1\}^n\to\{0,1\}^n$, note that you can put more into the function than you take out of it. Now you expect collisions after $2^{n/2}$ invokations, ie you have $n/2$-bit collision resistance which makes non-wide block ciphers (such as AES) unsuitable for usage as a core compression function in hash functions (because $2^{64}$ operations is feasible and a similar amount of work was done for the SHA-1 collision).
SEJPM
  • 46,697
  • 9
  • 103
  • 214
