I am trying to correct the x&y offsets in the Tevo Tarantula that I got from a friend in order that my printer is not printing over the end. What I got so far is that I need to measure and then enter the offsets into my configuration.h file, build the firmware and flash it to the board.
Because I do not have and can not find the original firmware I found the repository from Jim Brown for the Tarantula.
Looking into the top section of the config file provided by the repo, the board configured is
#define MOTHERBOARD BOARD_MKS_GEN_13        // Original controller board with built in stepper drivers. Works with MKS BASE 1.3, 1.4
However since the board in my Tarantula has 1.2 on it I checked the boards.h file for MKS but could not find the v1.2 :
#define BOARD_MKS_BASE          40    // MKS BASE v1.0
#define BOARD_MKS_BASE_15       405   // MKS v1.5 with Allegro A4982 stepper drivers
#define BOARD_MKS_BASE_HEROIC   41    // MKS BASE 1.0 with Heroic HR4982 stepper drivers
#define BOARD_MKS_GEN_13        47    // MKS GEN v1.3 or 1.4
#define BOARD_MKS_GEN_L         53    // MKS GEN L
#define BOARD_MKS_GEN_L_V2      54    // MKS GEN L V2
#define BOARD_ZRIB_V20          504   // zrib V2.0 control b
Any idea, what board configuration would be compatible for 1.2? Or is there any other way to correct the x&y offsets other then compiling them into the firmware?
0scar
  • 37,708
  • 68
  • 156
Eike
  • 103
The MKS Base v1.2 is basically an Arduino MEGA2560 and a RAMPS1.4 on a single board.
You can use the RAMPS pin designation.
Note that the endstop to origin distances is explained in question How to center my prints on the build platform? (Re-calibrate homing offset).
In Jims Marlin fork you can find this at:
#define X_MIN_POS 0 - XTRA_BED_LEFT
and
#define Y_MIN_POS 0 - XTRA_BED_BACK
Unfortunately, XTRA_BED_LEFT and XTRA_BED_BACK are defined as zero; this implies that the endstops define the origin (not likely) or it is left as an excercise for you to find out. This answer explains how you figure that out.
0scar
  • 37,708
  • 68
  • 156
