Unit testing means writing code that verifies individual parts, or units, of an application or library. A unit is the smallest testable part of an application. Unit tests assess code in isolation. In C++ this means writing tests for methods or functions. I am writing a basic calculator program and trying to use CPPUnitTest to test the code in Visual studio 2019.After that I have to build this in Jenkins too. Please don't judge .. I am writing unit Test for the 1st time .. this is my Calculator.cpp
#include <iostream>
#include "Calc.h"
using namespace std;
int main()
Calc obj;
float a, b;
cin >> a >> b;
int menu;
cout << "Enter what operation you want(1-4);" << endl;
cout << "1. Addition" << endl;
cout << "2. Subtraction" << endl;
cout << "3. Multiplication" << endl;
cout << "4. Division" << endl;
cin >> menu;
switch (menu)
case 1:obj.add(a, b);
break;
case 2:obj.sub(a, b);
break;
case 3:obj.multiply(a, b);
break;
case 4:
try
obj.divide(a, b);
catch (std::runtime_error& e)
cout << e.what() << "\n";
break;
default:
cout << "Invalid input" << endl;
This is class Calc or "Calc.h"
Here I have used std::runtime_error to throw error on division bye zero
#pragma once
#include <stdexcept>
class Calc {
public:
float add(float a, float b)
return a + b;
float sub(float a, float b) {
return a - b;
float multiply(float a, float b) {
return a * b;
float divide(float a, float b) {
if (b == 0)
throw std::runtime_error("Division by zero condition!");
return a / b;
I am trying to write unit test using CPPUnitTest for my code.
I have written code for add and subtract using assert::AreEqual but for divide by zero condition, I don't know to write the test case.
this is my unit test code.
#include "pch.h"
#include "CppUnitTest.h"
#include "../Calculator/Calc.h"
using namespace Microsoft::VisualStudio::CppUnitTestFramework;
namespace CalculatorTest
TEST_CLASS(CalculatorTest)
public:
Calc cal;
TEST_METHOD(AddTest)
float k = cal.add(3, 4);
Assert::AreEqual(7.0f,k);
TEST_METHOD(SubTest)
float k = cal.sub(3, 4);
Assert::AreNotEqual(-2.0f, k);
TEST_METHOD(DivByZeroTest)
//what should I write here
Please help me to write the test method for this .
Somewhere I read CPPUNIT_ASSERT_THROW(cal->divide(12,0), std::runtime_error); but this is not working in my case. How can I make Assert::AreEqual
Also suggest which else method I can use to increase my code coverage.
