I have just written a library which provides what you need. You only need to copy and paste it into the project and if you would like to add, expand and customize it depending on your requirements.
SqliteHandler.java
import android.content.Context;
import android.database.Cursor;
import android.net.Uri;
import android.util.Log;
class SqliteHandler {
// VERY IMPORTANT MAKE SURE IT'S CORRECT AND REGISTERED IN THE MANIFEST
private String PROVIDER_NAME = "com.example.android.mySqlite";
private String CONTENT_URL = "content://" + PROVIDER_NAME + "/";
private Context context;
SqliteHandler(Context context, String PROVIDER_NAME) {
this.context = context;
this.PROVIDER_NAME = PROVIDER_NAME;
Cursor exeQuery(String query) {
try {
queryObject obj = convertQueryStringToQueryObject(query);
return context.getContentResolver().query(obj.uri, obj.projection, obj.selection, obj.selectionArgs, null);
} catch (Exception e) {
e.printStackTrace();
return null;
Cursor exeQuery(String query, String[] selectionArgs) {
try {
return context.getContentResolver().query(obj.uri, obj.projection, obj.selection, selectionArgs, null);
return null;
Cursor exeQuery(String query, String selection, String[] selectionArgs) {
try {
return context.getContentResolver().query(obj.uri, obj.projection, selection, selectionArgs, null);
return null;
Cursor exeQuery(String query, String[] projection, String[] selectionArgs) {
try {
return context.getContentResolver().query(obj.uri, projection, obj.selection, selectionArgs, null);
return null;
Cursor exeQuery(queryObject obj) {
try {
return null;
class queryObject {
Uri uri;
String[] projection;
String selection;
String[] selectionArgs;
String sortOrder;
queryObject(String table_name, String[] projection, String selection, String[]
selectionArgs) {
this.uri = Uri.parse(CONTENT_URL + table_name);
this.projection = projection;
this.selection = selection;
this.selectionArgs = selectionArgs;
queryObject convertQueryStringToQueryObject(String query) {
try {
String selection = null;
String[] selectionArgs = null;
query = query.toLowerCase();
String[] s = query.split("select")[1].split("from");
String[] projection = s[0].split(",");
String[] s2 = s[1].split("where");
String table_name = s2[0];
String logText = "";
if (s2.length > 1) {
selection = s2[1];
String[] args = s2[1].split("=");
selectionArgs = new String[args.length - 1];// half of the args are values others are keys
int count = 0;
for (int i = 1; i < args.length; i++) {
selectionArgs[count] = args[i]
.split("and")[0]
.split("or")[0]
.replace(" ", "")
.replace("and", "")
.replace("or", "");
count++;
for (int i = 0; i < selectionArgs.length; i++) {
logText += selectionArgs[i];
if (i < selectionArgs.length - 1) logText += ",";
selection = selection.replace(selectionArgs[i], "?");
Log.i("table_name", table_name);
Log.i("selection: ", selection == null ? "null" : selection);
Log.i("selectionArgs", logText.equals("") ? "null" : logText);
logText = "";
for (int i = 0; i < projection.length; i++) {
logText += projection[i];
if (i < projection.length - 1) logText += ",";
Log.i("projection", logText);
return new queryObject(table_name, projection, selection, selectionArgs);
return null;
How To Use
instantiate SqliteHandler, it's very important to pass valid PROVIDER_NAME and also make sure that your CONTENT_PROVIDER was registered in the AndroidManiFest.xml. For an illustration of how does it work, we pass three different queries and get return values which are objects of type queryObject
SqliteHandler sh = new SqliteHandler(this,"PROVIDER_NAME");
SqliteHandler.queryObject obj1 = sh.convertQueryStringToQueryObject("SELECT * FROM table_name");
SqliteHandler.queryObject obj2 = sh.convertQueryStringToQueryObject("SELECT * FROM table_name WHERE _id = ?");
SqliteHandler.queryObject obj3 = sh.convertQueryStringToQueryObject("SELECT param1,param2,param3 FROM table_name WHERE param1 =\"a\" and param2=\"b\" or param3=\"c\"");
The method convertQueryStringToQueryObject converts query string into query class then we can use this class for getContentResolver().query().
Important Note: because getContentResolver().query() needs Uri. Therefore, we need to create a Uri from the table_name. As a result, we need to pass valid PROVIDER_NAME to the instance of SqliteHandler.
Output Log
As you can see the three different queries broke apart into parameters which we can use in the getContentResolver().query()
// 1th query
I/table_name: table_name
I/selection:: null
I/selectionArgs: null
I/projection: *
// 2th query
I/selection:: _id = ?
I/selectionArgs: ?
I/projection: *
// 3th query
I/selection:: param1 =? and param2=? or param3=?
I/selectionArgs: "a","b","c"
I/projection: param1,param2,param3
Complete Example
in The SqliteHandler.java there is the exeQuery method which has several overloads. Moreover, You can have a Cursor at the Content Provider depending on different input parameters.
Cursor c = sh.exeQuery(obj1);
Cursor c = sh.exeQuery(obj2);
Cursor c = sh.exeQuery(obj3);
Cursor c = sh.exeQuery("SELECT param1,param2,param3 FROM table_name WHERE param1 =\"a\" and param2=\"b\" or param3=\"c\"");
Cursor c = sh.exeQuery("SELECT * FROM table_name WHERE _id = ?",new String[]{"whereArg"});
Cursor c = sh.exeQuery("SELECT * FROM table_name"," _id = ? ",new String[]{"whereArg"});
Cursor c = sh.exeQuery("SELECT ? FROM table_name WHERE _id = ?",new String[]{"Field"},new String[]{"whereArg"});
However, if you don't want to use exeQuery try below walking through:
Cursor c = this.getContentResolver().query(obj.uri, obj.projection, obj.selection, obj.selectionArgs, null);
