I am trying to draw a sphere mesh that I can later modify to look like the leaves of a tree. However, there are also vertices in my pointsArray that precede those generated from my sphere mesh. I have an index buffer containing the indices for drawing each triangle in order, but I need to access the last portion of vertices that is my sphere mesh without having the index buffer draw triangles from the other vertices. Here I create buffers for the vertices, colors, and texture coordinates to transfer them to my shader code. I also have an index buffer created for the sphere mesh.
function loadBuffers()
// Load the colors for the triangles and enable the attribute vColor
var cBuffer = gl.createBuffer();
gl.bindBuffer( gl.ARRAY_BUFFER, cBuffer );
gl.bufferData( gl.ARRAY_BUFFER, flatten(colorsArray), gl.STATIC_DRAW );
var vColor = gl.getAttribLocation( program, "vColor" );
gl.vertexAttribPointer( vColor, 4, gl.FLOAT, false, 0, 0 );
gl.enableVertexAttribArray( vColor );
// Load the vertices for the triangles and enable the attribute vPosition
var vBuffer = gl.createBuffer();
gl.bindBuffer( gl.ARRAY_BUFFER, vBuffer );
gl.bufferData( gl.ARRAY_BUFFER, flatten(pointsArray), gl.STATIC_DRAW );
var vPosition = gl.getAttribLocation( program, "vPosition" );
gl.vertexAttribPointer( vPosition, 4, gl.FLOAT, false, 0, 0 );
gl.enableVertexAttribArray( vPosition );
var tBuffer = gl.createBuffer();
gl.bindBuffer( gl.ARRAY_BUFFER, tBuffer );
gl.bufferData( gl.ARRAY_BUFFER, flatten(texturesArray), gl.STATIC_DRAW );
var vTexCoord = gl.getAttribLocation( program, "vTexCoord" );
gl.vertexAttribPointer( vTexCoord, 2, gl.FLOAT, false, 0, 0 );
gl.enableVertexAttribArray( vTexCoord );
iBuffer = gl.createBuffer();
gl.bindBuffer(gl.ELEMENT_ARRAY_BUFFER, iBuffer);
console.log(indexBuffer);
gl.bufferData(gl.ELEMENT_ARRAY_BUFFER, new Uint16Array(indexBuffer), gl.STATIC_DRAW);
iBuffer.itemSize = 1;
iBuffer.numItems = indexBuffer.length;
Here is my sphere generation code:
function sphere()
genSphereVertices(1, 10, 10, 0, 0, 1.5);
plotSphere(10, 10);
function genSphereVertices(radius, latBands, lonBands, X, Y, Z)
var normRadius = 1;
for (var lat = 0; lat < latBands + 1; ++lat)
var theta = lat * Math.PI/latBands; //0 to pi
var z = normRadius * Math.cos(theta);
for (var lon = 0; lon < lonBands + 1; ++lon)
var phi = 2 * lon * Math.PI/lonBands;//0 to 2pi
var u = Math.sqrt((normRadius * normRadius) - (z * z));
var x = u * Math.cos(phi);
var y = u * Math.sin(phi);
//here I push my new x,y,z vertex to the pointsArray,
//however pointsArray is also being used to draw a building
//with textures
pointsArray.push(vec4((X+x)*radius, (Y+y)*radius, (Z+z)*radius, 1.0));
numVertices++;
colorsArray.push(faceColors[lon%7]);
function plotSphere(latBands, lonBands)
for (var lat = 0; lat < latBands; ++lat)
for (var lon = 0; lon < lonBands; ++lon)
//map indices to tell what order to connect each vertex
var vA = lat * (lonBands + 1) + lon;
var vB = vA + (latBands + 1);
var vC = vA + 1;
var vD = vB + 1;
indexBuffer.push(vA);
indexBuffer.push(vB);
indexBuffer.push(vC);
indexBuffer.push(vD);
And here is where I am trying to draw the sphere after I draw the rest of the vertices.
function render()
objOffset = 0;
if (loadedImageCount == imageTextures.length)//textures on building
for (var i = 0; i < numFaces; ++i)//move through each face and map textures to specific faces
if (i < 60){//walls
gl.uniform1i(fs_textureLoc, 0);
}else if (i < 69){//building tops
gl.uniform1i(fs_textureLoc, 1);
}else if (i < 73){//slanted rooves
gl.uniform1i(fs_textureLoc, 2);
}else if (i < 93){//stairs
gl.uniform1i(fs_textureLoc, 3);
//draw each face (each is a rect with 2 triangles)
gl.drawArrays(gl.TRIANGLES, objOffset, twoTriangles);
objOffset += twoTriangles;
//now I want to draw the sphere, but the index buffer is starting from
//the beginning of the pointsArray! :(
gl.drawElements(gl.TRIANGLES, iBuffer.numItems, gl.UNSIGNED_SHORT, 0);
//animate scene
requestAnimFrame(render);
When this code runs, the index buffer starts drawing from the beginning of the pointsArray, drawing all over the building. How do I start at an offset of the pointsArray to only use the index buffer for the sphere mesh
