I'm working with Visual Studio Community 2015 on a Visual Basic application targeting .NET 4.5. I didn't write the application so I added all the missing dependencies using NuGet but there are 3 dependencies I can't add no matter what I try. This is one of the many errors I get when building the project:
This project references NuGet package(s) that are missing on this computer. Enable NuGet Package Restore to download them. For more information, see http://go.microsoft.com/fwlink/?LinkID=317567.
This are the dependencies:
- System.IO
- System.Runtime
- System.Threading.Tasks
I tried installing them with NuGet but I get this error for example when trying to install System.IO that also installs System.Runtime and System.Threading.Tasks:
Could not install package 'System.Runtime 4.0.20'. You are trying to install this package into a project that targets '.NETFramework,Version=v4.5', but the package does not contain any assembly references or content files that are compatible with that framework. For more information, contact the package author.
I also tried to add them manually adding the .dll that in my case are in:
C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.5\Facades\System.IO.dllC:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.5\Facades\System.Runtime.dllC:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.5\Facades\System.Threading.Tasks.dll
But doesn't work neither. I also tried removing System.Runtime as it says here and the answer here, both without any success.
This is an image of my References:
