First of all, I saw this post(Entropy Solution of the Burger's Equation). Is it correct? What I mean is that, is the answer of this post entropy solution? I know this is correct, but I feel suspicious.
The reason why I feel suspicious is related to that problem;
"Construct entropy solution of $u_{t} + (\frac{u^{4}}{4})_{x} = 0$ with $u(x,0) =1$ if $x<0$, $u(x,0)=0$ otherwise."
First of all, I think I can use Lax-Olieniek formula since $F:=\frac{u^{4}}{4}$ is uniformly convex, so it ensure $G= (F')^{-1}$ is entropy solution. (Note that $x(s,t) = \frac{1}{4}t$). Then, some calculation denotes $G = u^{-3}$ and $u = 1$ if $x<t$, $u=0$ otherwise. So $G = u$. Is it right? I think I derive all the stuff properly,but I'm not sure it is entropy solution or not. Could you verify my construction?
