How to show that either $a^2+5b^2=p$ or $c^2+5d^2=2p$ has integer solutions for all prime $p$ with $(\frac{-5}{p})=1$
would the fact that $\mathbb{Z}[\sqrt{-5}]$=$\mathcal{O}\cap \mathbb{Q}[\sqrt{-5}]$ has class number $2$ be any use.
Ragnar
  • 6,253
104078
  • 1,929
Looking at the possible values of $a^2+5b^2 \pmod {5}$, we find that for any prime $p \neq 5$, $a^2 + b^2 = p \implies p \equiv 1,4 \pmod 5$ and $a^2 + b^2 = 2p \implies p \equiv 2,3 \pmod 5$
If $-5$ is a square modulo $p$, then $(p)$ splits in $\Bbb Z[\sqrt{-5}]$ into a product $\mathfrak p\bar{\mathfrak p}$, where $\mathfrak p$ has norm $p$.
Since $\Bbb Z[\sqrt{-5}]$ has class number $2$, we have that for any such prime,
$$Cl(\mathfrak p) = Cl(\Bbb Z[\sqrt{-5}]) \iff \exists y \in \Bbb Z[\sqrt{-5}], \mathfrak p = y\Bbb Z[\sqrt{-5}] \implies \\ \exists y \in \Bbb Z[\sqrt{-5}], p = N(y) \iff \exists a,b \in \Bbb Z, a^2+5b^2 = p \implies p \equiv 1,4 \pmod 5$$
and since the ideal $I = \langle 2, 1+\sqrt{-5}\rangle$ is a nonprincipal ideal of norm $2$, $I^2$ is principal, and :
$$Cl(\mathfrak p) = Cl(I) \iff Cl(I)Cl(\mathfrak p) = Cl(\Bbb Z[\sqrt{-5}]) \iff \exists y \in \Bbb Z[\sqrt{-5}], \mathfrak pI = y\Bbb Z[\sqrt{-5}] \implies \\ \exists y \in \Bbb Z[\sqrt{-5}], 2p = N(y) \iff \exists a,b \in \Bbb Z, a^2+5b^2 = 2p \implies p \equiv 2,3 \pmod 5$$
Once we realise that both the starting points and the ending points are mutually exclusive, and that the starting points cover all possible cases, we can replace the implications in the middle with equivalences.
Also, the only way for $a^2+5b^2$ to be even is to have $a$ and $b$ of the same parity. If you replace $a$ with $2c+b$, you obtain that for any integer $p$, $\exists a,b \in \Bbb Z, a^2+5b^2 = 2p \iff \exists b,c \in \Bbb Z, 2c^2+2bc+3b^2 = p$. This formulation is cleaner : it doesn't use the prime $2$ anymore (why use $2p$ rather than $3p$ or $7p$ or any other ?) and we are left with the two non-equivalent quadratic forms of discriminant $-20$
mercio
  • 51,119
  • thnaks. but I do not understand your solution. there are a lot points. for example, one point, i ll ask is: how do we use the discriminant? – 104078 Dec 20 '13 at 19:36
  • @user104078 I don't use the discriminant to prove the claim. I'm only making a remark on how in can be stated more cleanly – mercio Dec 20 '13 at 23:10
  • thanks.please,another question:where does the ideal $I=\lt 2,1+\sqrt{-5}\gt$ come from? and, could you clarify the third implication of the second part (similary, the seond impliation of the fisrt part ) where $\exists y$ such that... – 104078 Dec 20 '13 at 23:50
  • @user104078 : $I$ comes from stufying the ideal class group of $\Bbb Z[\sqrt{-5}]$. If you know it is of order $2$, you most likely know of one ideal that is not principal. Such as this one. The implications come from the fact that ideals have a norm, and if two ideals are the same, then they have the same norm. – mercio Dec 20 '13 at 23:55
  • thanks. for last: i do not totally undestand the part: $\mathcal{p}$=$y\mathbb{Z}[\sqrt{-5}]$. – 104078 Dec 21 '13 at 00:01
  • that's the definition of $Cl(\mathfrak p) = Cl(\Bbb Z[\sqrt{-5}])$ – mercio Dec 21 '13 at 00:05
  • no. more specifically, I do not know what the notation "$y\mathbb{Z}[\sqrt{-5}]$" means. – 104078 Dec 21 '13 at 00:09
  • it is the ideal consisting of multiples of $y$. – mercio Dec 21 '13 at 00:15
-1
The fact that you state doesn't seem to be of any relevance to me.
A hint to a solution: What can you say about $-5$ when $\left(\frac{-5}p\right)=1$? And how can you use that to find integer solutions for $a^2+5b^2=p$?
Ragnar
  • 6,253
