As we were taught in grade school, that $i = \sqrt{-1}$. This opened up math so that we could start solving real or complex functions for solutions.
As such, I was wondering if there exists a similar concept for extending the absolute value to allow for an inverse-like function. In otherwords, let $ι = |-1|^{-1}$ where $|x|^{-1}$ is the inverse of the absolute value function. Then $|ι| = -1$ and if we take the identity $|ab|=|a||b|$ then we also get $|±ι|=|-1||ι| = -1$ and with $|±1| = 1$ we have our definitions of the base units. We can expand it further to where given a positive real number $a$ we can then say $|±aι| = -a$.
But where I struggle to come up with a consistent definition for this idea is when I try to expand it to add real numbers.
How would I come up with a complete definition for $|a±bι| =?$ and $|a±bι|^{-1} = ?$
Edit: The reason I need this is that I am trying to solve ray-intersect complicated absolute value function by plugging in the ray equation $P=O+tD$ and solving for $t$. Which will let me come up systematically with equation to evaluate in a program.
Here is the equation:
let $a_x,a_y,b_x,b_y,d,x,y \in \mathbb{R}$
$a=\left(a_x,a_y\right)$
$b=\left(b_x,b_y\right)$
$C=\frac{\left(a+b\right)}{2}$
$q=b-a$
$M=\sqrt{q.x\cdot q.x+q.y\cdot q.y}$
$R=\frac{M}{2}\ -\ d$
$Q=\frac{q}{M}$
$K=\left(-Q.y,Q.x\right)$
$P=\left(x,y\right)$
$v\ =\ P-C$
$S\ =v.x\cdot Q.x+v.y\cdot Q.y$
$B\ =v.x\cdot K.x+v.y\cdot K.y$
$\frac{1}{2}\left|S^{2}-d^{2}\ \right|-d\left|S-d\ \right|-d\left|S+d\ \right|\ +\frac{1}{2}S^{2}+\frac{3}{2}d^{2}+\ B^{2}\ =\ R^{2}$
So then I would plug in $P=O+tD$ into $P=\left(x,y\right)$ and solve for $t$.
yosmo78
  • 227
    $\iota=|-1|^{-1}=1^{-1}=1$. How do you deduce $|\iota|=-1$? – Christophe Boilley May 28 '25 at 06:27
  • @ChristopheBoilley it is by definition, just like how we define $i = \sqrt{-1}$. I don't see how $|−1|^{−1}=1^{−1}$. Since $|x|^{-1}$ isn't the absolute value applied to $-1$ it is the inverse of the absolute value. Thats what I meant by my definition above. – yosmo78 May 28 '25 at 07:14
  • Related: https://math.stackexchange.com/questions/1345191/is-there-a-number-whose-absolute-value-is-negative, https://math.stackexchange.com/questions/259584/why-dont-we-define-imaginary-numbers-for-every-impossibility – Hans Lundmark May 28 '25 at 07:53
  • OK, so you want to extend the absolute value on $\mathbb R$ to a multiplicative function over a polynomial ring $\mathbb R[\iota]$ such that $|\iota|=-1$. You need to define your function on all irreducible polynomial. Some continuity condition imply that $|\iota+x|\sim|x|$ when $x\to\pm\infty$. – Christophe Boilley May 28 '25 at 08:30
  • @ChristopheBoilley exactly. This extension should be complete in the sense that I can plug in any value in the form $a±bι$ and be able to evaluate it in both the absolute value and the inverse of the absolute value – yosmo78 May 29 '25 at 04:19
