I've been working through past MIT Primes problems, and got stuck on 2021 Problem M4:
A particle is initially on the number line at a position of $0$. Every second, if it is at position $x$, it chooses a real number $t \in [−1, 1]$ uniformly and at random, and moves from $x$ to $x+t$. Find the expected value of the number of seconds it takes for the particle to exit the interval $(−1, 1)$.
I've been trying to solve it differently from the solution they provided. Let me outline my approach.
Let $X$ denote the number of seconds it takes the particle to exit $[-1, 1]$. Then, we are looking for
$$ \text{E}[X] = \sum_x x \Pr(X=x) $$
The PMF of $X$ is
$$ \Pr(X = x) = \Big( 1 - \Pr(-1 < X_x < 1) \Big) \prod_{i=1}^{x-1} \Pr(-1 < X_i < 1) $$
where $X_t$ is $X$ at time $t$. We have now punted the problem to finding $\Pr(-1 < X_i < 1)$ for all $i$. Remember, each $X_i$ is dependent on $X_{i-1}$. We can make a step towards finding $\Pr(-1 < X_i < 1)$ using the law of total probability:
$$ \Pr(X_i \leq x) = \int_{-\infty}^\infty \Pr(X_i \leq x \mid X_{i-1}=y) f_{X_{i-1}}(y) \ \text{d}y $$
$\Pr(X_i \leq x \mid X_{i-1}=y)$ can be defined as a piecewise function (I derived this by fixing $y$, and then considering $x$):
$$ \Pr(X_i \leq x \mid X_{i-1}=y) = \begin{cases} \frac{x+1}{2+y} & -1 \leq y < 0 \; \land \; x \leq y + 1 \\ 1 & -1 \leq y < 0 \; \land \; x > y + 1 \\ \frac{x-y+1}{2-y} & 0 \leq y < 1 \; \land \; x \geq y - 1 \\ 0 & 0 \leq y < 1 \; \land \; x < y - 1 \end{cases} $$
We also know that $f_{X_{i-1}}(y)$ is the derivative of $\Pr(X_{i-1} \leq y)$. Because $\Pr(X_1 \leq x) = (x + 1)/2$, we can now find $\Pr(X_2 \leq x)$.
Now here is the problem. I evaluated $\Pr(X_2 \leq x)$ using the following Mathematica script:
(* the piecewise function *)
XiCDFconditional[x_, y_] = Piecewise[{
{(x + 1) / (2 + y), -1 <= y < 0 && x <= y + 1},
{1, -1 <= y < 0 && x > y + 1},
{(x - y + 1) / (2 - y), 0 <= y < 1 && x >= y - 1},
{0, 0 <= y < 1 && x < y - 1}
X1CDF[x_] = (x + 1) / 2;
(* Pr(X2 <= x) *)
X2CDF[x_] = Integrate[XiCDFconditional[x, y] * X1CDF'[y], {y, -Infinity, Infinity}]
when I execute X2CDF[1] - X2CDF[-1] (i.e. $\Pr(-1 \leq X_2 \leq 1)$), I get $1$, which is obviously incorrect. Where did I screw up?
I feel like I might have subtly screwed up $\Pr(X_i \leq x \mid X_{i-1}=y)$. Or maybe I didn't screw up, and I'm almost surely (pun intended) getting confused in the continuous world.
