Is there a function / Are there such functions $f: \mathbb{R} \to \mathbb{R}$ which satisfies $f(f(x))=x^2-2$?
My Solution:
\begin{align} &\text{Let's look for $t_2$ which satisfies } f^2(t_2)=t_2. \\ &\Rightarrow t_2=2, -1. \\ \ \\ &\text{Now, let's look for $t_4$ which satisfies } f^4(t_4)=t_4. \\ &\Rightarrow f^4(t_4)=f^2(t_4^2-2) = t_4^4-4t_4^2+2. \\ &\text{let set }T_2 = \{t_2\}, T_4=\{t_4\}. \\ &\Rightarrow T_2 \subset T_4. \\ &n(T_4)=4, n(T_2)=2. \Rightarrow \text{let } T_4=\{2, -1, \alpha, \beta \}. (\alpha, \beta \not\in T_2.) \\ \ \\ &\text{I will define the $2$chain, $-1$chain, $\alpha$chain and $\beta$chain:} \\ \ \\ &\text{$2$chain}: \begin{bmatrix} 2 & \rightarrow & f(2) \\ \uparrow & \fbox{$2_\text{cyc}$} & \downarrow \\ f(2) &\leftarrow & 2 \end{bmatrix} \\ \ \\ -&\text{$1$chain}: \begin{bmatrix} -1 & \rightarrow & f(-1) \\ \uparrow & \fbox{$2_\text{cyc}$} & \downarrow \\ f(-1) & \leftarrow & -1 \end{bmatrix} \\ \ \\ &\text{$\alpha$chain}: \begin{bmatrix} \alpha & \rightarrow & f(\alpha) \\ \uparrow & \fbox{$4_\text{cyc}$} & \downarrow \\ f^3(\alpha) & \leftarrow & f^2(\alpha) \end{bmatrix} \\ \ \\ &\text{$\beta$chain}: \begin{bmatrix} \beta & \rightarrow & f(\beta) \\ \uparrow & \fbox{$4_\text{cyc}$} & \downarrow \\ f^3(\beta) & \leftarrow & f^2(\beta) \end{bmatrix} \\ \ \\ &\text{Let's look at $\alpha$chain.} \\ \ \\ &\text{if } f(\alpha)=\alpha \Rightarrow f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=2 \Rightarrow f^3(\alpha)=2, f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=-1 \Rightarrow f^3(\alpha)=-1, f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=\beta \Rightarrow \text{Let's look at $\beta$chain together.} \\ \ \\ &\text{if } f(\beta)=\beta \Rightarrow f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=2 \Rightarrow f^3(\beta)=2, f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=-1 \Rightarrow f^3(\beta)=-1, f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=\alpha \Rightarrow \text{Going back to the $\alpha$chain, } f^2(\alpha)=\alpha, \text{Contradiction.} \\ \ \\ &\therefore \not\exists f: \mathbb{R} \to \mathbb{R} \text{ s.t. } f(f(x))=x^2-2. \end{align}
P.S.
- You can prove this with $f^3(\alpha)$, too. I recommend trying this!
Prove that there isn't such function $f: \mathbb{R} \to \mathbb{R}$ satisfying $f(f(x))-x^2+x+3=0$.
My Solution:
\begin{align} &\text{Let's take a look at $t_2$ which satisfies $f^2(t_2)=t_2$.} \\ &\Rightarrow t_2^2-2t_2-3=0, t_2=-1, 3. \\ \ \\ &\text{Now, let]s take a look at $t_4$ which satisfies $f^4(t_4)=t_4$.} \\ &\Rightarrow (t_4^2-t_4-3)^2-(t_4^2-t_4-3)-3=t_4. \\ &\therefore t_4 \text{ has $4$ solution.}\\ \ \\ &\text{let set $T_2=\{t_2\}$, $T_4=\{t_4\}$.} \\ &T_2 \subset T_4, \ n(T_2)=2, \ n(T_4)=4. \Rightarrow T_2=\{-1, 3\}, T_4=\{-1, 3, \alpha, \beta \} (\alpha, \beta \neq -1, 3.) \\ \ \\ &\text{Now, I will define $-1$chain, $3$chain, $\alpha$chain and $\beta$chain:} \\ \ \\ -&\text{$1$chain}: \begin{bmatrix} -1 & \rightarrow & f(-1) \\ \uparrow & \fbox{$2_\text{cyc}$} & \downarrow \\ f(-1) & \leftarrow & -1 \end{bmatrix} \\ \ \\ &\text{$3$chain}: \begin{bmatrix} 3 & \rightarrow & f(3) \\ \uparrow & \fbox{$2_\text{cyc}$} & \downarrow \\ f(3) & \leftarrow & 3 \end{bmatrix} \\ \ \\ &\text{$\alpha$chain}: \begin{bmatrix} \alpha & \rightarrow & f(\alpha) \\ \uparrow & \fbox{$4_\text{cyc}$} & \downarrow \\ f^3(\alpha) & \leftarrow & f^2(\alpha) \end{bmatrix} \\ \ \\ &\text{$\beta$chain}: \begin{bmatrix} \beta & \rightarrow & f(\beta) \\ \uparrow & \fbox{$4_\text{cyc}$} & \downarrow \\ f^3(\beta) & \leftarrow & f^2(\beta) \end{bmatrix} \\ \ \\ &\text{Let's look at $\alpha$chain.} \\ \ \\ &\text{if } f(\alpha)=\alpha \Rightarrow f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=-1 \Rightarrow f^3(\alpha)=-1, f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=3 \Rightarrow f^3(\alpha)=3, f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=\beta \Rightarrow \text{Let's look at $\beta$chain together.} \\ \ \\ &\text{if } f(\beta)=\beta \Rightarrow f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=-1 \Rightarrow f^3(\beta)=-1, f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=3 \Rightarrow f^3(\beta)=3, f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=\alpha \Rightarrow \text{Going back to the $\alpha$chain, } f^2(\alpha)=\alpha, \text{Contradiction.} \\ \ \\ &\therefore \not\exists f: \mathbb{R} \to \mathbb{R} \text{ s.t. } f(f(x))-x^2+x+3=0. \end{align}
P.S. If you want, you can try solving this one with a chain solution:
$$f(f(x))=x^2-14x+56.$$
Check your Solution:
\begin{align} &\text{Let's look for $t_2$ which satisfies $f^2(t_2)=t_2.$} \\ &\Rightarrow t_2=7, 8. \\ \ \\ &\text{Now, let's look for $t_4$ which satisfies $f^4(t_4)=t_4.$} \\ &\Rightarrow f^4(t_4)=f^2(t_4^2-14t_4+56)=(t_4^2-14t_4+56)^2-14(t_4^2-14t_4+56)+56. \\ & \therefore \text{$t_4$ has $4$ solution.} \\ \ \\ &\text{let set $T_2=\{t_2\}$, $T_4=\{t_4\}$.} \\ &\Rightarrow n(T_2)=2, n(T_4)=4, T_2 \subset T_4. \Rightarrow \text{let }T_4-T_2=\{\alpha, \beta \}. \\ & \Rightarrow T_2=\{7, 8\}, T_4=\{7, 8, \alpha, \beta \}. \\ \ \\ &\text{I will define the $7$chain, $8$chain, $\alpha$chain and $\beta$chain:}\\ \ \\ & \text{$7$chain}: \begin{bmatrix} 7 & \rightarrow & f(7) \\ \uparrow & \fbox{$2_\text{cyc}$} & \downarrow \\ f(7) &\leftarrow & 7 \end{bmatrix} \\ \ \\ &\text{$8$chain}: \begin{bmatrix} 8 & \rightarrow & f(8) \\ \uparrow & \fbox{$2_\text{cyc}$} & \downarrow \\ f(8) &\leftarrow & 8 \end{bmatrix} \\ \ \\ &\text{$\alpha$chain}: \begin{bmatrix} \alpha & \rightarrow & f(\alpha) \\ \uparrow & \fbox{$4_\text{cyc}$} & \downarrow \\ f^3(\alpha) & \leftarrow & f^2(\alpha) \end{bmatrix} \\ \ \\ &\text{$\beta$chain}: \begin{bmatrix} \beta & \rightarrow & f(\beta) \\ \uparrow & \fbox{$4_\text{cyc}$} & \downarrow \\ f^3(\beta) & \leftarrow & f^2(\beta) \end{bmatrix} \\ \ \\ &\text{if } f(\alpha)=\alpha \Rightarrow f^2(\alpha)=\alpha, \text{Contradiction.} \\&\text{if } f(\alpha)=7 \Rightarrow f^3(\alpha)=7,f^2(\alpha)=\alpha, \text{Contradiction.} \\&\text{if } f(\alpha)=8 \Rightarrow f^3(\alpha)=8, f^2(\alpha)=\alpha, \text{Contradiction.} \\ &\text{if } f(\alpha)=\beta \Rightarrow \text{Let's look at $\beta$chain together.} \\ \ \\ &\text{if } f(\beta)=\beta \Rightarrow f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=7 \Rightarrow f^3(\beta)=7, f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=8 \Rightarrow f^3(\beta)=8, f^2(\beta)=\beta, \text{Contradiction.} \\ &\text{if } f(\beta)=\alpha \Rightarrow \text{Going back to the $\alpha$chain, } f^2(\alpha)=\alpha, \text{Contradiction.} \\ \ \\ \end{align}
