I have this
$$ | \xi |^{2} = 1 - 4p^{2}(1-p^{2})s^{4}$$
where $s = \sin\left(\frac\omega 2 \right)$. The method is said to be stable if $ | \xi|\leq1$.
From here I am supposed to deduce that this scheme is stable for $ -1 \leq p \leq 1$, but I do not know where to go from here... Can anyone suggest how?
EditPiAf
  • 21,328
italy
  • 1,051
  • What is the premise and what is the conclusion precisely? – DeepSea Apr 25 '18 at 18:23
  • VON Neumann stability analysis, what do you mean by given~? – italy Apr 25 '18 at 18:24
  • https://math.stackexchange.com/questions/2743887/lax-wendroff-method-for-linear-advection-stability-analysis/2744346?noredirect=1#comment5678143_2744346 this is the full question and I am stuck at this point – italy Apr 25 '18 at 18:33
Hints:
  1. If $p^2\in[0,1]$ then $4p^2(1-p^2)\in [0, 1]$, say by AM-GM.
  2. If $p^2>1$, then $(1-p^2)$ is negative, so your LHS is $>1$ unless $s=0$.
Macavity
  • 48,039
  • Can you explain the first first line of your comment? What is AmM GM?? – italy Apr 26 '18 at 08:04
  • AM-GM refers to the inequality between Arithmetic Mean and Geometric Mean. If that’s not familiar, note $(x+y)^2=(x-y)^2+4xy\geqslant 4xy$. Now set $x=p^2$ and $y=1-p^2$. – Macavity Apr 26 '18 at 11:43
Is this a correct analysis?
$ 1-4p^{2}(1-p^{2}) s^{4} \leq 1 $
$ -4p^{2}(1-p^{2}) s^{4} \leq 0 $
$ p^{2}(1-p^{2}) \geq 0$ Since sine is bounded between 0 and 1
$p^{2} \geq 0 $ is always true. So $ 1-p^{2} \geq 0 $ gives $p^{2} \leq 1 $
EditPiAf
  • 21,328
italy
  • 1,051
