Question: Let $a_n$ be a positive nonzero integer. Are there any known criteria in order for $$\sqrt{a_1+\sqrt{a_2-\sqrt{a_3+\sqrt{a_4-\sqrt{a_5+\ldots}}}}}$$ to converge ?
The motivation here was the initial question: Should we believe $$\sqrt{2+\sqrt{3-\sqrt{5+\sqrt{7-\sqrt{11+\ldots}}}}}$$ converges ? One could equally be curious about $$\sqrt{2+\sqrt{4-\sqrt{6+\sqrt{8-\sqrt{10+\ldots}}}}}$$ and compare that to the nested radical constant. Also observe $$\sqrt{1+\sqrt{2-\sqrt{3+\sqrt{4-\sqrt{5+\ldots}}}}}$$ appears to be a complex number in stark contrast to the nested radical constant. So I guess we should be concerned knowing if $\sqrt{a_1+\sqrt{a_2-\sqrt{a_3+\sqrt{a_4-\sqrt{a_5+\ldots}}}}}$ is a real number.
Note Vijayaraghavan special case of Herschfeld's theorem on nested radicals. But this does not apply to alternating plus and minus. Click here for Herschfeld's paper on nested radicals
bof
  • 82,298
Anthony
  • 4,078
  • 16
  • 35
  • Just to do a comment, not related with your question: maybe you can to state different problems using different arithmetic functions. That I evoke is that instead of your pattern of signs $+,-,+,\ldots$ inside the nested radicals maybe it is interesting do experiments with a computer with functions as the Möbius function or Liouville function (for examples of $ \left{ a_n\right}_{n=1}^\infty $). Isn't required a response of this comment, good day. –  Sep 29 '17 at 00:40
A search for "nested radical" brings up this article in mathworld:
http://mathworld.wolfram.com/NestedRadical.html
It only generally talks about radicals where all the signs are positive, unlike your case.
It mentions a theorem that mignt be relevant:
Herschfeld's convergence theorem:
If $0 < p < 1$ and all $x_i \ge 0$ then $\lim_{n \to \infty} x_0 +(x_1+(x_2+(...x_n^p)^p)^p)^p $ exists if and only if $ (x_n)^{p^n}$ is bounded.
The references are
Herschfeld, A. "On Infinite Radicals." Amer. Math. Monthly 42, 419-429, 1935.
Jones, D. J. "Continued Powers and a Sufficient Condition for Their Convergence." Math. Mag. 68, 387-392, 1995.
Your question involves $p = \frac12$.
marty cohen
  • 110,450
