13
Let $A\subset B$ be an integral extension of commutative, unital rings.
We have the well-known "incomparability", "lying-over", and "going-up" theorems (5.9-5.11 in Atiyah-Macdonald, or see here). Lying-over asserts that every prime of $A$ has a prime of $B$ that contracts to it ("lies over" it). Incomparability asserts that two distinct primes of $B$ that lie over the same prime of $A$ are incomparable i.e. neither contains the other. Going-up asserts that if there is a chain of primes in $A$ and you fix a prime of $B$ lying over the minimal prime in this chain, then there exists a chain of primes in $B$ of the same length, each lying over the corresponding prime of $A$, with your fixed prime as the minimal member.
We also have the "going-down theorem" (Atiyah-Macdonald 5.16 or same link as before), but only if $A$ and $B$ are domains and $A$ is integrally closed. This is like the going-up theorem except you fix a prime of $B$ lying over the maximal prime of the chain in $A$, and extend downward instead of upward.
I just realized I may have been subtly assuming the existence of a "going-in-between theorem":
If $\mathfrak{q}_1\subset\mathfrak{q}_2$ are primes of $B$ and $\mathfrak{p}_1\subset\mathfrak{p}_2$ are their intersections with $A$, then incomparability implies that if $\mathfrak{p}_2$ covers $\mathfrak{p}_1$ (i.e. there are no primes properly between them), then the same is true about $\mathfrak{q}_2$ and $\mathfrak{q}_1$.
I thought that the converse was true as well, i.e. that if $\mathfrak{q}_2$ covers $\mathfrak{q}_1$, then $\mathfrak{p}_2$ covers $\mathfrak{p}_1$.
But I realize now that I believed this due to a faulty application of the going-up theorem. If there is a prime of $A$ between $\mathfrak{p}_1$ and $\mathfrak{p}_2$, going-up asserts there will be a prime of $B$ lying over it and containing $\mathfrak{q}_1$, but there is no guarantee that it will be inside $\mathfrak{q}_2$.
Going-up can guarantee it will be contained in some prime of $B$ lying over $\mathfrak{p}_2$, but not necessarily $\mathfrak{q}_2$.
Does it ever happen in an integral ring extension $A\subset B$ that a covering relation $\mathfrak{q}_1\subset\mathfrak{q}_2$ in $B$ intersects with $A$ to yield primes $\mathfrak{p}_1$ and $\mathfrak{p}_2$ with a properly intermediate prime $\mathfrak{p}_1\subset\mathfrak{p}^\star\subset \mathfrak{p}_2$? What's an example?
If it does happen, then how bad does a ring have to be for it to happen? Can it happen in a noetherian ring? Or is it ruled out somehow by the Krull height theorem? If it can happen in a noetherian ring, how about a catenary ring? (Obviously not a local catenary ring.) How about a Cohen-Macaulay ring?
Aside: This question is motivated by a technical point in an argument I gave in this question.
Second aside: It seems clear to me on geometric grounds that the proposed $\mathfrak{p}^\star$ cannot exist if $A$ and $B$ are affine coordinate rings over a field: for in this setting, if $\mathfrak{q}_1$ is covered by $\mathfrak{q}_2$, then $V(\mathfrak{q}_1)$ is an irreducible variety, and $V(\mathfrak{q}_2)$ is a codimension one irreducible subvariety, and $V(\mathfrak{p}_1)$ and $V(\mathfrak{p}_2)$ are their images under a dimension-preserving map, in which case what is $V(\mathfrak{p}^\star)$'s dimension? But this logic bundles a lot of nuanced dimension theory into a black box. This question is an attempt to open the box and examine the contents.
    Really interesting question! My gut says it's true either in general or in most rings under relatively mild niceness conditions – Stella Biderman Feb 27 '17 at 04:41
    Related (another question from you ;-)): https://mathoverflow.net/questions/264489/ – Watson Nov 22 '18 at 17:32
    @Watson - yes, I asked that question after this one went unanswered :) For readers here, in comments at Watson's link, Fred Rohrer turned up the following very relevant paper: L.J.Ratliff Jr., Going between rings and contractions of saturated chains of prime ideals, Rocky Mountain J. Math. 7 (1977), 777-787 – Ben Blum-Smith May 17 '19 at 12:04
I'm surprised this never got properly answered! I am teaching commutative algebra this semester and just came across this same subtlety (in working out the argument for the catenary property of finitely-generated algebras over a field).
It sounds like there might be counterexamples in general. For finitely-generated algebras, though, the proof is actually quite short and direct, so I thought I would post it here. (Ratliff's paper contains results and assertions that imply it, using a bit more machinery and general theory.)
Proposition 1. Let $\phi : A \to B$ be an integral morphism of finitely-generated algebras over a field. Let $\mathfrak{q}_1 \subsetneq \mathfrak{q}_2$ be a strict minimal inclusion of prime ideals in $B$ and let $\mathfrak{p}_i := \phi^{-1}(\mathfrak{q}_i)$. Then $\mathfrak{p}_1 \subsetneq \mathfrak{p}_2$ is a strict, minimal inclusion.
Proof. Strictness follows by the incomparability property. By quotienting by $\mathfrak{q}_1$ and $\mathfrak{p}_1$ we can assume $\mathfrak{q}_1 = \mathfrak{p}_1 = 0$. Now $A \subseteq B$ is an integral extension of finitely-generated domains over a field, $\operatorname{ht} \mathfrak{q}_2 = 1$ and we want to show $\operatorname{ht} \mathfrak{p}_2 = 1$. Note that the usual way to get equality of heights is by the Going-Down property, which we may not have here. Fortunately:
Proposition 2. Let $A \subseteq B$ be an integral extension of finitely-generated domains over a field. Let $\mathfrak{q} \subseteq B$ be a prime ideal. Then $\operatorname{ht} \mathfrak{q} = \operatorname{ht} \mathfrak{q} \cap A.$
Proof. Let $k[x_1, \ldots, x_n] \subset A$ be a Noether normalization. Then we have $$\operatorname{ht} \mathfrak{q} \leq \operatorname{ht} \mathfrak{q} \cap A \leq \operatorname{ht} \mathfrak{q} \cap k[x_1, \ldots, x_n] = \operatorname{ht} \mathfrak{q}.$$ The two inequalities follow from the incomparability property. The equality is from the Going-Down property from $B$ to $k[x_1, \ldots, x_n]$. //
So, given $\mathfrak{p}_1 \subsetneq \mathfrak{p}^\star \subsetneq \mathfrak{p}_2$, we do indeed find some $\mathfrak{q}_1 \subsetneq \mathfrak{q}^\star \subsetneq \mathfrak{q}_2$. Note however that we have not asserted that $\mathfrak{q}^\star$ lies over $\mathfrak{p}^\star$.
Jake Levinson
  • 6,321
  • 17
  • 22
    Beautiful! Regarding the final comment: as indeed, we cannot, per pinaki's example here https://mathoverflow.net/a/264663/12419 – Ben Blum-Smith Apr 15 '24 at 03:27
    It also looks like Nagata's example of a non-catenary ring also more or less directly gives (along the way) an example of an integral extension of integral domains, in which a height-1 prime lies over a height-2 prime: https://mathoverflow.net/a/430169 – Jake Levinson Apr 15 '24 at 04:34
