Find all integer solutions to linear congruences:
\begin{align} &(a) &3x &\equiv 24 \pmod{6},\\ &(b) &10x &\equiv 18 \pmod{25},\\ \end{align}
What I have so far:
$$(a) \gcd(3,6)=3$$ And we know $3|24$ so there are $3$ solutions. By inspection we know that $x=8$ is a solution.
One, question I have is, even though $x=8$ is a solution, I can also see that $x=2$ is a solution, and among others. Does it matter which I choose, or do I randomly choose a solution I see? From here I'm a tad confused. I'm missing something very simple.
$$(b) \gcd (10,25)=5$$
And $5 \nmid 18$ so there are no solutions. Right?
Using this, $(10,25)=5$ must divide $9$ to admit any solution, which is not, so there is no solution.
$3x\equiv 24\pmod 6\implies 2\mid x$ i.e., any even value(not only $8$) of $x$ will satisfy the 1st congruence.
So, the system of the linear congruence has no solution as the 2nd congruence is not solvable.
Alternatively, for the 2nd congruence, $10x-18=25y$ for some integer $y$,
So,$5(2x-5y)=18, \frac{18}5=2x-5y$ which is an integer, hence contradiction.
  • So, for $(a)$ I see: $$\begin{align} & 3x &\equiv 0 \pmod{6},\ & 3x &\equiv 6 \pmod{6},\ & 3x &\equiv 12 \pmod{6},\\end{align}$$ So, $x=0,2,4...$ Are the solutions. How would I say this on an exam? – student.llama Oct 16 '12 at 16:23
  • @student.llama, From the 1st line of your comment, $6\mid 3x\implies 2\mid x$ – lab bhattacharjee Oct 16 '12 at 16:24
In (a) you say there are three solutions. In fact you should say there are three, modulo $6$. These are $0$, $2$ and $4$, and so all even $x$ are solutions to the original expression.
In (b) you are correct. Clearly $10x$ is always a multiple of $5$ and numbers equivalent to $18 \pmod{ 25}$ never are.
Henry
  • 169,616
