For example, when $\alpha = 2$, $\ln(z^{2}) \neq 2\ln(z)$, because argument z is determined up to constant $2 \pi k$. So
$$ \ln(z^{2}) = \ln(z) + \ln(z) = \ln(z_{k_{1}}) + \ln(z_{k_{2}}) \neq 2\ln(z_{k_{3}}). $$
Of course, two of correct answers - $1, -1$. But I know, that there are an infinite number of answers for $\alpha$. Can you help me?
Asaf Karagila
  • 405,794
John Taylor
  • 1,775
Using this and this,
$Log (a+ib)^{x+iy}$ $=\frac{1}{2}x\log (a^2+b^2)-y(2m\pi+\tan ^{-1}\frac{b}{a})+i(\frac{1}{2}y\log (a^2+b^2)+x(2m\pi+\tan ^{-1}\frac{b}{a}))$
$Log (a+ib)= \frac{1}{2}\log (a^2+b^2)+i(2n\pi+\tan ^{-1}\frac{b}{a})$
$(x+iy)Log (a+ib)$ $=\frac{1}{2}x\log (a^2+b^2)-y(2n\pi+\tan ^{-1}\frac{b}{a})+i(x(2n\pi+\tan ^{-1}\frac{b}{a})+\frac{1}{2}y\log (a^2+b^2))$
The principal values will be same if $-\pi<\frac{1}{2}y\log (a^2+b^2)+x\tan ^{-1}\frac{b}{a}\le \pi$ else $2r\pi$ (where $r$ is any integer) must be added to this argument to adjust its value in $(-\pi, \pi]$.
If $x=0$ or $(b=0$ and $a>0 ⇔ \tan ^{-1}\frac{b}{a}=0)$ , the condition becomes $-\pi<\frac{1}{2}y\log (a^2+b^2)\le \pi$
If $y=0$ or $a^2+b^2=1 ⇔ \log (a^2+b^2)=0$, the condition becomes $-\pi<x\tan ^{-1}\frac{b}{a}\le \pi$
If $y=0$ or $a^2+b^2=1$ and $x=-1$ the condition becomes $-\pi<-\tan ^{-1}\frac{b}{a}\le \pi\implies \pi>\tan ^{-1}\frac{b}{a}\ge -\tan ^{-1}\frac{b}{a}$ which is true for all $a,b$.
If $y=0,x=2$ the condition becomes $-\pi<2\tan ^{-1}\frac{b}{a}\le \pi $
$\implies -\frac{\pi}2<\tan ^{-1}\frac{b}{a}\le \frac{\pi}2$ i.e, $a>0$.
AsukaMinato
  • 1,007
  • Thank you! But how did you get a condition $$ -\pi < \frac{1}{2}y ln(a^{2} + b^{2}) + x arctg\left(\frac{b}{a}\right) \leqslant \pi ? $$ – John Taylor Sep 26 '12 at 03:56
  • Please look into http://en.wikipedia.org/wiki/Argument_(complex_analysis)#Principal_value and http://en.wikipedia.org/wiki/Atan2 – lab bhattacharjee Sep 26 '12 at 05:23
  • Thank you! You helped me very much. – John Taylor Sep 27 '12 at 18:07
  • There is another solution of this problem, as I think. For simplifying I make for $\alpha$ value $x = Real$. So for $z = re^{i(\varphi + 2 \pi k)}$ I can earn for multivalued $Ln(z^{\alpha})$
    $$ Ln(z^{\alpha}) = \alpha\left(i(\varphi + 2 \pi k) + ln(r)\right) + 2 \pi j i = \alpha \left(i(\varphi + 2 \pi k) + ln(r) \right) + 2 \pi j i \qquad (.1), $$
    and for $\alpha Ln(z)$
    $$ \alpha(Ln(z)) = \alpha (i(\varphi + 2 \pi n) + ln(r)) . $$
    So
    $$ \alpha (Ln(z)) = Ln(z^{\alpha}) \Rightarrow |(.1)| \Rightarrow 2 \pi i ( j + \alpha k ) = \alpha 2 \pi i n. $$
    – John Taylor Sep 28 '12 at 16:14
  • So, $\alpha = \frac{1}{n}, n$ - any whole number. – John Taylor Sep 28 '12 at 16:15
