Find the equations which all points inside the triangle formed by the points $(1,3)$, $(5,0)$ and $(-1,2)$ must satisfy
Now the answer mentioned is $$3x+2y \ge 0$$$$2x+y-13 \ge0$$$$2x-3y-12 \le0$$
Now I found the equation of the triangular sides and tried to use the fact that any arbitrary point $(x,y)$ and the vertex of the triangle opposite to the side must lie on the same same and hence formed three equation but I couldn't reach the correct answer.
Please give hints only. You needn't do the calculation. Just give me suitable hints from where I can take my work ahead.
Harsh Sharma
  • 2,389
