60
I am having trouble seeing the difference between weak and strong induction.
There are a few examples in which we can see the difference, such as reaching the $k^{th}$ rung of a ladder and proving every integer $>1$ can be written as a product of primes:
To show every $n\ge2$ can be written as a product of primes, first we note that $2$ is prime. Now we assume true for all integers $2 \le m<n$. If $n$ is prime, we're done. If $n$ is not prime, then it is composite and so $n=ab$, where $a$ and $b$ are less than $n$. Since $a$ and $b$ are less than $n$, $ab$ can be written as a product of primes and hence $n$ can be written as a product of primes. QED
However, it seems sort of like weak induction, only a bit dubious. In weak induction, we show a base case is true, then we assume true for all integers $k-1$, (or $k$), then we attempt to show it is true for $k$, (or $k+1$), which implies true $\forall n \in \mathbb N$.
When we assume true for all integers $k$, isn't that the same as a strong induction hypothesis? That is, we're assuming true for all integers up to some specific one.
As a simple demonstrative example, how would we show $1+2+\cdots+n= {n(n+1) \over 2}$ using strong induction?
(Learned from Discrete Mathematics by Kenneth Rosen)
user5826
  • 12,524
Initial remarks: Good question. I think it deserves a full response (warning: this is going to be a long, but hopefully very clear, answer). First, most students do not really understand why mathematical induction is a valid proof technique. That's part of the problem. Second, weak induction and strong induction are actually logically equivalent; thus, differentiating between these forms of induction may seem a little bit difficult at first. The important thing to do is to understand how weak and strong induction are stated and to clearly understand the differences therein (I disagree with the previous answer that it is "just a matter of semantics"; it's not, and I will explain why). Much of what I will have to say is adapted from David Gunderson's wonderful book Handbook of Mathematical Induction, but I have expanded and tweaked a few things where I saw fit. That being said, hopefully you will find the rest of this answer to be informative.
Gunderson remark about strong induction: While attempting an inductive proof, in the inductive step one often needs only the truth of $S(n)$ to prove $S(n+1)$; sometimes a little more "power" is needed (such as in the proof that any positive integer $n\geq 2$ is a product of primes--we'll explore why more power is needed in a moment), and often this is made possible by strengthening the inductive hypothesis.
Kenneth Rosen remark in Discrete Mathematics and Its Applications Study Guide: Understanding and constructing proofs by mathematical induction are extremely difficult tasks for most students. Do not be discouraged, and do not give up, because, without doubt, this proof technique is the most important one there is in mathematics and computer science. Pay careful attention to the conventions to be observed in writing down a proof by induction. As with all proofs, remember that a proof by mathematical induction is like an essay--it must have a beginning, a middle, and an end; it must consist of complete sentences, logically and aesthetically arranged; and it must convince the reader. Be sure that your basis step (also called the "base case") is correct (that you have verified the proposition in question for the smallest value or values of $n$), and be sure that your inductive step is correct and complete (that you have derived the proposition for $k+1$, assuming the inductive hypothesis that proposition is true for $k$--or the slightly strong hypothesis that it is true for all values less than or equal to $k$, when using strong induction.
Statement of weak induction: Let $S(n)$ denote a statement regarding an integer $n$, and let $k\in\mathbb{Z}$ be fixed. If
  • (i) $S(k)$ holds, and
  • (ii) for every $m\geq k, S(m)\to S(m+1)$,
then for every $n\geq k$, the statement $S(n)$ holds.
Statement of strong induction: Let $S(n)$ denote a statement regarding an integer $n$. If
  • (i) $S(k)$ is true and
  • (ii) for every $m\geq k, [S(k)\land S(k+1)\land\cdots\land S(m)]\to S(m+1)$,
then for every $n\geq k$, the statement $S(n)$ is true.
Proof of strong induction from weak: Assume that for some $k$, the statement $S(k)$ is true and for every $m\geq k, [S(k)\land S(k+1)\land\cdot\land S(m)]\to S(m+1)$. Let $B$ be the set of all $n>m$ for which $S(n)$ is false. If $B\neq\varnothing, B\subset\mathbb{N}$ and so by well-ordering, $B$ has a least element, say $\ell$. By the definition of $B$, for every $k\leq t<\ell, S(t)$ is true. The premise of the inductive hypothesis is true, and so $S(\ell)$ is true, contradicting that $\ell\in B$. Hence $B=\varnothing$. $\blacksquare$
Proof of weak induction from strong: Assume that strong induction holds (in particular, for $k=1$). That is, assume that if $S(1)$ is true and for every $m\geq 1, [S(1)\land S(2)\land\cdots\land S(m)]\to S(m+1)$, then for every $n\geq 1, S(n)$ is true.
Observe (by truth tables, if desired), that for $m+1$ statements $p_i$, $$ [p_1\to p_2]\land[p_2\to p_3]\land\cdots\land[p_m\to p_{m+1}]\Rightarrow[(p_1\land p_2\land\cdots\land p_m)\to p_{m+1}],\tag{$\dagger$} $$ itself a result provable by induction (see end of answer for such a proof).
Assume that the hypotheses of weak induction are true, that is, that $S(1)$ is true, and that for arbitrary $t, S(t)\to S(t+1)$. By repeated application of these recent assumptions, $S(1)\to S(2), S(2)\to S(3),\ldots, S(m)\to S(m+1)$ each hold. By the above observation, then $$ [S(1)\land S(2)\land\cdots\land S(m)]\to S(m+1). $$ Thus the hypotheses of strong induction are complete, and so one concludes that for every $n\geq 1$, the statement $S(n)$ is true, the consequence desired to complete the proof of weak induction. $\blacksquare$
Proving any positive integer $n\geq 2$ is a product of primes using strong induction: Let $S(n)$ be the statement "$n$ is a product of primes."
Base step ($n=2$): Since $n=2$ is trivially a product of primes (actually one prime, really), $S(2)$ is true.
Inductive step: Fix some $m\geq 2$, and assume that for every $t$ satisfying $2\leq t\leq m$, the statement $S(t)$ is true. To be shown is that $$ S(m+1) : m+1 \text{ is a product of primes}, $$ is true. If $m+1$ is a prime, then $S(m+1)$ is true. If $m+1$ is not prime, then there exist $r$ and $s$ with $2\leq r\leq m$ and $2\leq s\leq m$ so that $m+1=rs$. Since $S(r)$ is assumed to be true, $r$ is a product of primes [note: This is where it is imperative that we use strong induction; using weak induction, we cannot assume $S(r)$ is true]; similarly, by $S(s), s$ is a product of primes. Hence $m+1=rs$ is a product of primes, and so $S(m+1)$ holds. Thus, in either case, $S(m+1)$ holds, completing the inductive step.
By mathematical induction, for all $n\geq 2$, the statement $S(n)$ is true. $\blacksquare$
Proof of $1+2+3+\cdots+n = \frac{n(n+1)}{2}$ by strong induction: Using strong induction here is completely unnecessary, for you do not need it at all, and it is only likely to confuse people as to why you are using it. It will proceed just like a proof by weak induction, but the assumption at the outset will look different; nonetheless, just to show what I am talking about, I will prove it using strong induction.
Let $S(n)$ denote the proposition $$ S(n) : 1+2+3+\cdots+n = \frac{n(n+1)}{2}. $$
Base step ($n=1$): $S(1)$ is true because $1=\frac{1(1+1)}{2}$.
Inductive step: Fix some $k\geq 1$, and assume that for every $t$ satisfying $1\leq t\leq k$, the statement $S(t)$ is true. To be shown is that $$ S(k+1) : 1+2+3+\cdots+k+(k+1)=\frac{(k+1)(k+2)}{2} $$ follows. Beginning with the left-hand side of $S(k+1)$, \begin{align} \text{LHS} &= 1+2+3+\cdots+k+(k+1)\tag{by definition}\\[1em] &= (1+2+3+\cdots+k)+(k+1)\tag{group terms}\\[1em] &= \frac{k(k+1)}{2}+(k+1)\tag{by $S(k)$}\\[1em] &= (k+1)\left(\frac{k}{2}+1\right)\tag{factor out $k+1$}\\[1em] &= (k+1)\left(\frac{k+2}{2}\right)\tag{common denominator}\\[1em] &= \frac{(k+1)(k+2)}{2}\tag{desired expression}\\[1em] &= \text{RHS}, \end{align} we obtain the right-hand side of $S(k+1)$.
By mathematical induction, for all $n\geq 1$, the statement $S(n)$ is true. $\blacksquare$
$\color{red}{\text{Comment:}}$ See how this was really no different than how a proof by weak induction would work? The only thing different is really an unnecessary assumption made at the beginning of the proof. However, in your prime number proof, strong induction is essential; otherwise, we cannot assume $S(r)$ or $S(s)$ to be true. Here, any assumption regarding $t$ where $1\leq t\leq k$ is really useless because we don't actually use it anywhere in the proof, whereas we did use the assumptions $S(r)$ and $S(s)$ in the prime number proof, where $1\leq t\leq m$, because $r,s < m$. Does it now make sense why it was necessary to use strong induction in the prime number proof?
Proof of $(\dagger)$ by induction: For statements $p_1,\ldots,p_{m+1}$, we have that $$ [p_1\to p_2]\land[p_2\to p_3]\land\cdots\land[p_m\to p_{m+1}]\Rightarrow[(p_1\land p_2\land\cdots\land p_m)\to p_{m+1}]. $$
Proof. For each $m\in\mathbb{Z^+}$, let $S(m)$ be the statement that for $m+1$ statements $p_i$, $$ S(m) : [p_1\to p_2]\land[p_2\to p_3]\land\cdots\land[p_m\to p_{m+1}]\Rightarrow[(p_1\land p_2\land\cdots\land p_m)\to p_{m+1}]. $$ Base step: The statement $S(1)$ says $$ [p_1\to p_2]\Rightarrow [(p_1\land p_2)\to p_2], $$ which is true (since the right side is a tautology).
Inductive step: Fix $k\geq 1$, and assume that for any statements $q_1,\ldots,q_{k+1}$, both $$ S(1) : [q_1\to q_2]\Rightarrow [(q_1\land q_2)\to q_2] $$ and $$ S(k) : [q_1\to q_2]\land[q_2\to q_3]\land\cdots\land[q_k\to q_{k+1}]\Rightarrow[(q_1\land q_2\land\cdots\land q_k)\to q_{k+1}]. $$ hold. It remains to show that for any statements $p_1,p_2,\ldots,p_k,p_{k+1},p_{k+2}$ that $$ S(k+1) : [p_1\to p_2]\land[p_2\to p_3]\land\cdots\land[p_{k+1}\to p_{k+2}]\Rightarrow[(p_1\land p_2\land\cdots\land p_{k+1})\to p_{k+2}] $$ follows. Beginning with the left-hand side of $S(k+1)$, \begin{align} \text{LHS} &\equiv [p_1\to p_2]\land\cdots\land[p_{k+1}\to p_{k+2}]\land[p_{k+1}\to p_{k+2}]\\[0.5em] &\Downarrow\qquad \text{(definition of conjunction)}\\[0.5em] &[[p_1\to p_2]\land[p_2\to p_3]\land\cdots\land[p_{k+1}\to p_{k+2}]]\land[p_{k+1}\to p_{k+2}]\\[0.5em] &\Downarrow\qquad \text{(by $S(k)$ with each $q_i = p_i$)}\\[0.5em] &[(p_1\land p_2\land\cdots\land p_k)\to p_{k+1}]\land[p_{k+1}\to p_{k+2}]\\[0.5em] &\Downarrow\qquad \text{(by $S(1)$ with $q_1=p_1\land\cdots\land p_k)$ and $q_2=p_{k+1}$)}\\[0.5em] &[[(p_1\land p_2\land\cdots\land p_k)\land p_{k+1}]\to p_{k+1}]\land [p_{k+1}\to p_{k+2}]\\[0.5em] &\Downarrow\qquad \text{(by definition of conjunction)}\\[0.5em] &[(p_1\land p_2\land\cdots\land p_k\land p_{k+1}]\to p_{k+1}]\land [p_{k+1}\to p_{k+2}]\\[0.5em] &\Downarrow\qquad \text{(since $a\land b\to b$ with $b=[p_{k+1}\to p_{k+2}]$)}\\[0.5em] &[(p_1\land p_2\land\cdots\land p_k\land p_{k+1})\to p_{k+2}]\land[p_{k+1}\to p_{k+2}]\\[0.5em] &\Downarrow\qquad \text{(since $a\land b\to a$)}\\[0.5em] &(p_1\land p_2\land\cdots\land p_k\land p_{k+1})\to p_{k+2}\\[0.5em] &\equiv \text{RHS}, \end{align} we obtain the right-hand side of $S(k+1)$, which completes the inductive step.
By mathematical induction, for each $n\geq 1, S(n)$ holds. $\blacksquare$
  • 10
    This has to be one of the longest answers I've seen. Bravo. – Cameron L. Williams Mar 11 '15 at 03:10
  • 16
    @CameronWilliams Thanks. My real hope here is that people not on MSE (as well as those on it, of course) will actually stumble across this answer so as to help them in understanding what the difference is between weak and strong induction. I thought a detailed analysis was in order. Here's hoping many people will find this answer helpful! – Daniel W. Farlow Mar 11 '15 at 03:12
    That's a good mentality. :) – Cameron L. Williams Mar 11 '15 at 03:15
  • Your proofs of induction look fishy. E.g. in second proof you assumed [S(1)∧S(2)∧⋯∧S(m)]→S(m+1) and then proved [S(1)∧S(2)∧⋯∧S(m)]→S(m+1). That certainly valid but it does not make sense in a context. – Trismegistos Mar 11 '15 at 16:55
  • @Trismegistos You may want to read what all I am saying more closely; then you can see it's not fishy or full of carp. :) – Daniel W. Farlow Mar 13 '15 at 02:42
  • As my comment here indicates, it is never "necessary" to use strong induction, because weak induction already includes everything that strong induction includes: http://math.stackexchange.com/a/1184640/630 Of course, what Gunderson says is perfectly correct: the important thing is to choose an inductive hypothesis strong enough to prove the theorem at hand. – Carl Mummert Mar 10 '16 at 12:05
  • This answer is very long and I didn't finish reading yet (inline commenting, StackExchange, please??), but I wanted to ask that in your first proof example, it is unclear what "$n$ is a product of primes" means. I'm assuming it means $n$ can be factored into only prime numbers? Or it could be taken to (falsely) mean that $n$ is a product of two prime numbers. – chharvey Oct 01 '16 at 03:44
  • @chharvey "The Fundamental Theorem of Arithmetic" is that all integers can be expressed as a product of primes. You can Google that phrase for more background. – Joseph Garvin Mar 26 '17 at 22:42
  • Sir, As we can prove any postive integer $n≥2$ is product of prime using strong induction. But you said that both weak and strong induction are equivalent. So can we prove same result using weak induction? – Akash Patalwanshi May 16 '20 at 13:53
    Unfortunately all these plausible and intuitive explanations are technically false. What is worse, it is not only taught at freshman year, but also popular belief in mathematical community. For "equivalence of the statements" to be meaningful at all, there have to be concrete theory fixed. In first order Peano arithmetic there is no equivalence between any of: weak induction, strong induction, or well ordering. To "prove" each other one needs more strength by adding part of ZF, or second order PA. So whatever is understood by such vague "equivalence" is surely not "logical equivalence". – Przemek Nov 17 '20 at 16:30
  • For the reference: https://link.springer.com/article/10.1007/s00283-019-09898-4
    https://www.jstor.org/stable/2317124?origin=JSTOR-pdf
    – Przemek Nov 17 '20 at 16:35
  • I certainly would not say they're logically equivalent. Even setting aside specific theories and rigorous notions of logical equivalence, in a purely intuitive way: it's quite possible to have a system where a statement like S(1)^S(2)^...^S(m) is simply not expressible. In such a system it is quite plausible that you could prove more with strong induction than weak induction. – Marcel Besixdouze Jun 23 '22 at 13:51
  • is induction an axiom on the natural numbers? (as per Terence Tao's Analysis I where it is presented as Axion 2.5)
    and if so, is strong induction a consequence of the basic induction, rather than being at the "same level" (I don't want to use the work equivalent !) ?
    – Penelope Sep 17 '23 at 17:39
Usually, there is no need to distinguish between weak and strong induction. As you point out, the difference is minor. In both weak and strong induction, you must prove the base case (usually very easy if not trivial). Then, weak induction assumes that the statement is true for size $n-1$ and you must prove that the statement is true for $n$. Using strong induction, you assume that the statement is true for all $m<n$ (at least your base case) and prove the statement for $n$.
In practice, one may just always use strong induction (even if you only need to know that the statement is true for $n-1$). In the example that you give, you only need to assume that the formula holds for the previous case (weak) induction. You could assume it holds for every case, but only use the previous case. As far as I can tell, it is really just a matter of semantics. There are times when strong induction really is more useful, the case when you break up the problem into two problem of size $n/2$ for example. This happens frequently when making proofs about graphs where you decompose the graph on $n$ vertices into two subgraphs (smaller, but you have little or no control over the exact size).
TravisJ
  • 7,556
  • 28
  • 42
    Also, we can always just use weak induction, and change the induction hypothesis as needed. For example, our new hypothesis $H(n)$ might be "the property I am interested in holds for every number less than $n$". Then we can try to prove that $H(n)$ holds for all $n$ by weak induction, which is the same as proving they have the property we are really interested in by strong induction. For this reason, the difference between weak and strong induction is entirely an illusion. – Carl Mummert Mar 10 '16 at 12:03
