9
I would like to solve that limit solved using only rules of algebra of limits.
$$\lim_{x\to0}\frac{e^x-1-x}{x^2}$$
All the answers in How to find $\lim\limits_{x\to0}\frac{e^x-1-x}{x^2}$ without using l'Hopital's rule nor any series expansion? do not fully address my question.
A challenging limit problem for the level of student who knows that: $$\begin{align*} \lim\limits_{x\to +\infty} e^x&=+\infty\tag1\\ \lim\limits_{x\to -\infty} e^x&=0\tag2\\ \lim\limits_{x\to +\infty} \frac{e^x}{x^n}&=+\infty\tag3\\ \lim\limits_{x\to -\infty} x^ne^x&=0\tag4\\ \lim\limits_{x\to 0} \frac{e^x-1}{x}&=1\tag5 \end{align*}$$
Educ
  • 4,940
8 Answers8
23
$$ \lim\limits_{x\to 0}\dfrac{e^x-1-x}{x^2} = \lim\limits_{x\to 0}\left(\dfrac{1}{e^x+1+x}\right)\lim\limits_{x\to 0}\dfrac{e^{2x}-(1+x)^2}{x^2} = \dfrac{1}{2}\lim\limits_{x\to 0}\left(4\dfrac{e^{2x}-1-2x}{4x^2}-1\right) = 2\lim\limits_{x\to 0}\left(\dfrac{e^{2x}-1-2x}{4x^2}\right)-\dfrac{1}{2} = 2\lim\limits_{x\to 0}\left(\dfrac{e^x-1-x}{x^2}\right)-\dfrac{1}{2}. $$
Therefore,
$$\lim\limits_{x\to 0}\dfrac{e^x-1-x}{x^2} = \dfrac{1}{2}\,.$$
This can be extended in a natural way. Define $s_{n}(x):=\sum\limits_{k=0}^{n-1}\dfrac{x^k}{k!}$ and observe the following: $$ \begin{eqnarray*} \lim_{x\to0}\dfrac{e^x-s_{n}(x)}{x^n} &=& \lim_{x\to0}\left(\dfrac{1}{\sum\limits_{r=0}^{n-1}e^{rx}(s_n(x))^{n-1-r}}\right)\lim_{x\to0}\dfrac{e^{nx}-(s_n(x))^n}{x^n} \\ &&\ \\ \ \\ &=& \dfrac{1}{n}\left(\lim_{x\to0}\dfrac{e^{nx}-s_n(nx)-\frac{n^{n-1}-1}{(n-1)!}x^n-o(x^n)}{x^n}\right)\\ &&\ \\ \ \\&=& n^{n-1}\lim_{x\to0}\left(\dfrac{e^{nx}-s_n(nx)}{(nx)^n}\right)-\frac{n^{n-1}-1}{n!}\,, \end{eqnarray*} $$
where, upon expansion, the polynomial $(s_n(x))^n = s_n(nx) + \frac{n^{n-1}-1}{(n-1)!}x^n + o(x^n)$. Consequently,
$$ \lim_{x\to0}\dfrac{e^x-s_n(x)}{x^n} = \dfrac{1}{n!}\,. $$
The foregoing arguments require the existence of the primary limits being sought after. Given that our hypothetical pupil is not armed with sophisticated $\epsilon, \delta$ analysis techniques, it is difficult to see how he might proceed in showing existence. Indeed, how does this pupil even know what a limit is, let alone the algebraic laws that follow by definition? Nevertheless, with these concerns in mind, we might at least allow our student one more atom of information: the interchange of limits for the particular class of functions we are interested in here. Thus, our pupil proceeds, somewhat mechanistically, as follows:
$$ \begin{eqnarray*} \lim\limits_{x\to 0}\frac{e^{x}-s_n(x)}{x^n} &=& \lim\limits_{x\to 0}\lim\limits_{y\to 0}\frac{\left(e^{y}(\frac{e^{x}-1}{x})-\frac{1}{x}\Big(s_n(x+y)-s_n(y)\Big)\right)}{\Big(\sum\limits_{r=0}^{n-1}(x+y)^r y^{n-1-r}\Big)} \\ &&\ \\&=& \lim\limits_{y\to 0}\lim\limits_{x\to 0}\frac{\left(e^{y}(\frac{e^{x}-1}{x})-\frac{1}{x}\Big(s_n(x+y)-s_n(y)\Big)\right)}{\Big(\sum\limits_{r=0}^{n-1}(x+y)^r y^{n-1-r}\Big)} \\ &&\ \\&=& \frac{1}{n}\lim\limits_{y\to 0}\frac{\left(e^{y}-s_{n-1}(y)\right)}{y^{n-1}}\,. \end{eqnarray*}$$
So, by successive application of such interchanges, our pupil deduces
$$ \lim\limits_{x\to 0}\frac{e^{x}-s_n(x)}{x^n} = \frac{1}{n!}\,. $$
ki3i
  • 5,142
    This is very interesting. Can all the terms of the Taylor series of $e^x$ be done similarly? – GEdgar Mar 09 '15 at 14:01
    I believe that you use here assumption that the limit exists. Can you show the existence of limit? – Wojowu Mar 09 '15 at 15:20
  • @GEdgar, please see edits. – ki3i Mar 10 '15 at 19:20
  • @Wojowu, please see edits – ki3i Mar 10 '15 at 19:21
  • What is it about "$e$" that make this work? Why won't this work for $a^x$ also? Is it because the first case $\lim (e^x-1)/x = 1$ is for $e$ only, and does not follow algebraically like the rest? – GEdgar Mar 10 '15 at 21:46
  • @GEdgar, An analogous development can be used for the function $a^x$, I suspect, where one specifies $\lim_{x\to 0}\frac{a^x-1}{x} = \log a$. Nothing special about $e^x$ or "$e$" in this sense. Of course, the functions $s_n(x)$ will need to be appropriately defined. – ki3i Mar 10 '15 at 22:23
    nice work. the conjugates. need to remember that. – abel Mar 10 '15 at 23:13
    Nice trick. Alas it only works if you know the limit exists. – Git Gud Mar 10 '17 at 23:00
9
$$\left(\frac{e^x-1}x\right)^2=\frac{e^{2x}-2e^x+1}{x^2}=2^2\frac{e^{2x}-1-2x}{(2x)^2}-2\frac{e^x-1-x}{x^2}.$$
Then, taking the limit,
$$1=4L-2L.$$
UPDATE: the same approach can be used for the next order,
$$\left(\frac{e^x-1}x\right)^3=\frac{e^{3x}-3e^{2x}+3e^x-1}{x^3}=3^3f(3x)-3\cdot2^3(2x)+3f(x),$$ where $f(x)=\dfrac{e^x-1-x-\dfrac{x^2}2}{x^3},$ and $$1=27L-24L+3L.$$
  • Just a shorter version than that of @ki3i. –  Mar 09 '15 at 13:47
    I originally thought the question was kind of stupid. But I see from these two answers that I was wrong. – GEdgar Mar 10 '15 at 21:43
    @GEdgar: I was myself amazed and pleased to discover that the whole Taylor development can be derived from the initial limit. –  Mar 11 '15 at 07:35
In order to show that
$$\lim_{x\to0}{e^x-1-x\over x^2}={1\over2}$$
it suffices to show that
$$\lim_{x\to0}{1\over x^2}\int_0^x(e^u-1-u)\,du=0$$
Let $g(u)=e^u-1-u$. Since $g'(u)=e^u-1$ and $g''(u)=e^u$, we see that $g(u)$ has a global minimum at $u=0$, with $g(0)=0$. Consequently
$$0\le{1\over x^2}\int_0^x(e^u-1-u)\,du\le{1\over x}\int_0^x{e^u-1-u\over u}\,du\quad\text{for }x\not=0$$
By the Mean Value Theorem,
$$\lim_{x\to0}{1\over x}\int_0^x{e^u-1-u\over u}\,du=\lim_{u\to0}{e^u-1-u\over u}$$
But
$$\lim_{u\to0}{e^u-1-u\over u}=\lim_{u\to0}{g(u)-g(0)\over u-0}=g'(0)=0$$
Thus, by the Squeeze Theorem, $\lim_{x\to0}{1\over x^2}\int_0^x(e^u-1-u)\,du=0$.
Barry Cipra
  • 81,321
Note that
$$e^x-1-x= \int_0^x (e^t-1)\, dt = \int_0^x \int_0^t e^s\,ds\, dt.$$
Now $1\le e^s \le e^x$ above. Thus $e^x-1-x$ lies between
$$\tag 1 \int_0^x \int_0^t 1 \,ds\, dt,\, \,\,\int_0^x \int_0^t e^x\,ds\, dt.$$
The first iterated integral in $(1)$ equals $x^2/2,$ the one on the right equals $e^x(x^2/2).$ So we have $e^x-1-x$ between $x^2/2$ and $e^x(x^2/2).$ Dividing by $x^2$ and using the squeeze theorem gives $1/2$ for the desired limit.
zhw.
  • 107,943
One could consider the more general limit:
$$L_n=\lim_{x\to0}x^{-n}(e^x-P_{n-1}(x))$$
where
$$P_n(x)=\sum_{k=0}^n\frac{x^k}{k!}$$
It may be easily seen that
$$e^x-P_n(x)=\int_0^xe^t-P_{n-1}(t)~\mathrm dt$$
And by induction,
$$e^x-P_{n-1}(x)=\int_0^x\int_0^{\sigma_n}\dots\int_0^{\sigma_2}e^{\sigma_1}~\mathrm d\sigma_1~\mathrm d\sigma_2\dots\mathrm d\sigma_n$$
By Cauchy's repeated integral formula, it can be seen that
$$e^x-P_{n-1}(x)=\frac1{(n-1)!}\int_0^x(x-t)^{n-1}e^t~\mathrm dt$$
And by substituting $t=xu$, this simplifies down to
$$e^x-P_{n-1}(x)=\frac{x^n}{(n-1)!}\int_0^1(1-u)^{n-1}e^{xu}~\mathrm du$$
Which so nicely cancels the $x^n$, and likewise, it is easy to see that
$$\int_0^1(1-u)^{n-1}e^{-|x|}~\mathrm du<\int_0^1(1-t)^{n-1}e^{xu}~\mathrm du<\int_0^1(1-u)^{n-1}e^{|x|}~\mathrm du$$
So by the squeeze theorem,
$$\begin{align}\lim_{x\to0}x^{-n}(e^x-P_{n-1}(x))&=\lim_{x\to0}\frac1{(n-1)!}\int_0^1(1-u)^{n-1}e^{xu}~\mathrm du\\&=\frac1{(n-1)!}\int_0^1(1-u)^{n-1}~\mathrm du\\&=\frac1{(n-1)!}\frac1n\\&=\frac1{n!}\end{align}$$
As expected.
$$\lim_{x\to0} \dfrac{e^x-1-x}{x^2}= \lim_{x\to0} \dfrac{e^{-x}-1+x}{x^2}= \lim_{x\to0} \dfrac{e^x+e^{-x}-2}{2x^2}=\displaystyle \dfrac{1}{2} \lim_{x\to0} \Bigg(\dfrac{e^{\frac{x}{2}}-e^{\frac{-x}{2}}}{x}\Bigg)^2$$ $$=\displaystyle \dfrac{1}{2} \lim_{x\to0} \Bigg(\dfrac{e^{\frac{x}{2}}-1}{x}-\dfrac{e^{\frac{-x}{2}}-1}{x}\Bigg)^2=\dfrac{1}{2} \Bigg(\dfrac{1}{2}-\dfrac{-1}{2}\Bigg)^2=\dfrac{1}{2}$$
Substitute $h=x^2$: it's $$\lim_{h \to 0} \frac{e^{\sqrt{h}}-\sqrt{h}-1}h$$ which is the derivative of $x \mapsto e^{\sqrt{x}}-\sqrt{x}$ evaluated at $x=0$.
Now use the chain rule: it's $$\lim_{x \to 0} \frac{e^{\sqrt{x}}-1}{2 \sqrt{x}} = \frac{1}{2}\lim_{h \to 0} \frac{e^h - 1}{h}$$
That latter limit is $\exp'(0)= 1$.
  • You are not trying to apply chain rule but rather trying to implicitly use the fact that if $g(x) =e^{\sqrt{x}} - \sqrt{x} $ then $g'$ is continuous on $[0,\infty)$. This requires that you already know that $g'(0)=1$. Instead you have proved that $\lim_{x\to 0}g'(x)=1$. – Paramanand Singh Oct 08 '18 at 14:25
-2
$$e^x=1+x+\frac{1}{2}x^2+o(x^2)_{x\to0}\\ \lim_{x\to0}\frac{e^x-1-x}{x^2}=\lim_{x\to0}\frac{1+x+\frac{1}{2}x^2+o(x^2)-1-x}{x^2}= \lim_{x\to0}\frac{\frac{1}{2}x^2+o(x^2)}{x^2}=\frac{1}{2}+0 $$ ($f=o(x^2)\Leftrightarrow\lim_{x\to0}\frac{f(x)}{x^2}=0$)
maxuel
  • 515
