Let $H$ be a Hilbert space with an orthonormal base $e_i$ and $L$ the left shift operator $L\in B(H)$: $(x_1, x_2, \dots) \mapsto (x_2, x_3, \dots)$.
I computed the spectrum could someone please tell me if this is right?
My work:
$\lambda \in \sigma (L)$ if and only if there exists $x \in H$ ($x\neq 0$) such that $$ (L-\lambda)(x) = (x_2 - \lambda x_1, x_3 - \lambda x_2, \dots) = 0$$
If $\lambda = 0$ then it quickly follows that $x=0$. For $\lambda \neq 0$ this is true if and only if $x$ is of the form $(x_1,\lambda x_1, \lambda^2 x_1, \dots)$.
Hence $\sigma (L) = \mathbb C \setminus \{0\}$.
First, in general case the spectrum consists of much more than eigenvalues: the resolvent set is $$R(L)=\{z\in\Bbb C: L-zI \text{ is continuously invertible}\}$$ and $$\sigma(L)=\overline{\Bbb C\setminus R(L)}.$$
Second, in your case, you can explicitly write $$(L-zI)x = (x_2-zx_1,x_3-zx_2,\ldots).$$
Fix $z\in \Bbb C$. If for an arbitrary $\epsilon>0$ you can find an $x \in H$ such that $\|x ,H\|=1$ and $\|Lx -zx ,H\|\le \epsilon$, then this value of $z$ is not in the resolvent set.
The trivial case $z=0$ is done by taking $x=(1,0,0,\ldots)$, which gives $\|Lx\|=0$, therefore $0\in\sigma(L)$.
Can you take it from here?
TZakrevskiy
  • 23,308
  • I don't understand your first sentence. If $A$ is a unital banach algebra then the spectrum is defined to be $$ \sigma (T) = {\lambda \in \mathbb C \mid T - \lambda \notin \mathrm{Inv}(A)}$$ Could you elaborate on your first sentence? I think an operator is invertible if and only if its kernel is ${0}$. –  Dec 15 '14 at 00:46
    @student There is more to invertibility in infinite dimensions (i.e. in an infinite dimensional Banach space) than kernel=0. You also have to be surjective, which is a separate condition. – Olivier Bégassat Dec 15 '14 at 00:49
  • @OlivierBégassat Right, thank you for pointing it out! –  Dec 15 '14 at 00:51
    What is the notation $|x,H|=1$? I have never seen this before. –  Dec 15 '14 at 01:02
  • Also, I see you are using a different definition of the spectrum. Is there a way to arrive at the same conclusions using my definition (i.e. without knowing $\sigma (L) = \overline{\mathbb C \setminus R(L)}$)? –  Dec 15 '14 at 01:44
  • @student $|x,H|$ means "the norm of vector $x$ in the normed space $H$". This notation can come handy when you are working with many different spaces at once or when you don't want to write undescrores with underscores with undescores. – TZakrevskiy Dec 15 '14 at 08:21
  • @student as per the definition of $\sigma(L)$, mine and yours are equiavalent. – TZakrevskiy Dec 15 '14 at 08:22
  • I looked it up. Why do you write the closure? Here it's just equality: $$ \sigma(L) = \mathbb C \setminus R(L)$$ –  Dec 21 '14 at 01:19
  • I also tried to find the condition with $\varepsilon$ that you're using to find $z$ that aren't in the resolvent set but I couldn't find it. –  Dec 21 '14 at 01:51
Note that $L$ is nothing but the adjoint of the unweighted shift $S$ defined by $$S(x_1,x_2,...):=(0,x_1,x_2,...),~(x=(x_1,x_2,...)\in H).$$ It is known that the spectrum of $S$ is the closed unit disc $\overline{\Bbb{D}}$, and so $$\sigma(L)=\overline{\sigma(L^*)}=\overline{\sigma(S)}=\overline{\Bbb{D}}.$$ If you are not familiar with shit operators, you may argue as follows. Note that $$\|Lx\|^2=\sum\limits_{k>1}{|x_k|^2}\leq \|x\|^2=\sum\limits_{k>0}{|x_k|^2}$$ for all $x=(x_1,x_2,...)\in H$. Hence, $\|L\|\leq1$ but since $$\|L(0,1,0,...)\|=\|(1,0,0,...)\|=1,$$ we see that $\|L\|=1$ and $$(*)~~~~~~~~~~~~~~~~\sigma(L)\subset\{\lambda\in\Bbb{C}:|\lambda|\leq\|L\|=1\}=\overline{\Bbb{D}}.$$ Now, let us solve $$(L-\lambda I)(x_1,x_2,...)=0.$$ This implies that $x_2-\lambda x_1=0$, $x_3-\lambda x_2=0$, $x_4-\lambda x_3=0$, ... Therefore, $x_2=\lambda x_1$, $x_3=\lambda x_2=\lambda^2x_1$, $x_4=\lambda x_3=\lambda^3 x_1=$, ... So, for any $n$, we have $$x_n=\lambda^{n-1}x_1.$$ Take $x_1=1$, to see that $$(L-\lambda I)(1,\lambda,\lambda^2,\lambda^3,...)=0.$$ Then the only thing that we need to check is when $(1,\lambda,\lambda^2,\lambda^3,...)$ is in $H$. This holds true only if $$\sum_{k\geq 0}|\lambda|^{2k}=\|(1,\lambda,\lambda^2,\lambda^3,...)\|^2<\infty.$$ But the radius of convergence of this series is 1, and \begin{equation} \Bbb{D}=\{\lambda:|\lambda|<1\}\subset\sigma(L). \end{equation} Since $\sigma(L)$ is compact (in particular closed), we get that \begin{equation} (**)~~~~~~~~~~~~~~~~\overline{\Bbb{D}}=\{\lambda:|\lambda|\leq1\}\subset\sigma(L). \end{equation} Clearly, by (*) and (**), we have \begin{equation} \sigma(L)=\overline{\Bbb{D}}=\{\lambda:|\lambda|\leq1\}. \end{equation}
Abdel
  • 29
