Let’s assume that four participants (A, B, C and D) take on five sport-challenges (e.g. swimming, running, ...). Our goal is to predict the placement of each participant for each challenge. Moreover, let’s assume we have appropriate predictors. We know that each placement (1 to 4) is unique for each challenge (only one winner ...).
My questions:
I think this prediction task is a multi-label multi-output classification, right?
Are there any algorithms, which provide unique forecasts (for each class). In other words, the algorithm should classify each person in one unique class (1 to 4). Obviously, we know a priori that same placements are very unlikely.
Thank you!
Greets
Blackout
  • 23
2 Questions.
  1. I think this prediction task is a multi-label multi-output classification, right?
Yes. But you could consider splitting these joint classification tasks into seperate ones (i.e. for swimming whats the placement of A,B,C,D etc) IF you data allows it.
  1. Are there any algorithms, which provide unique forecasts (for each class)?
Think in terms of probabilities. The strongest (most discriminatory one) is the one that has the highest-not-so-much-overlapping probabilities to different outputs. So taking these probabilities and "rounding" (possibly forcing some predictions if model is highly uncertain---meaning, for example, that he predicts 25% for every placement, here some other heuristics should be used. For example create a new variable that says how did competitor fare in other competitions etc) that up will give unique classes.
Noah Weber
  • 5,829
  • 13
  • 26
