I am fine tuning masked language model from XLM Roberta large on google machine specs. When I copy the model using gsutil and subprocess from container to GCP bucket it gives me error.
Versions
  Versions torch==1.11.0+cu113
  torchvision==0.12.0+cu113
  torchaudio==0.11.0+cu113
  transformers==4.17.0
I am using pre-trained Hugging face model.
I launch it as train.py file which I copy inside docker image and use vertex-ai ( GCP) to launch it using Containerspec
machineSpec = MachineSpec(machine_type="a2-highgpu-4g",accelerator_count=4,accelerator_type="NVIDIA_TESLA_A100")
python -m torch.distributed.launch --nproc_per_node 4 train.py --bf16
I am using
https://huggingface.co/xlm-roberta-large
tokenizer = tr.XLMRobertaTokenizer.from_pretrained("xlm-roberta-large",local_files_only=True)
model = tr.XLMRobertaForMaskedLM.from_pretrained("xlm-roberta-large", return_dict=True,local_files_only=True)
Training Code
training_args = tr.TrainingArguments(
 output_dir='****'
,logging_dir='****'        # directory for storing logs
,save_strategy="epoch"
,run_name="****"
,learning_rate=2e-5
,logging_steps=1000
,overwrite_output_dir=True
,num_train_epochs=10
,per_device_train_batch_size=4
,prediction_loss_only=True
,gradient_accumulation_steps=2
,gradient_checkpointing=True
,bf16=True #57100
,optim="adafactor"
trainer = tr.Trainer( model=model, args=training_args, data_collator=data_collator, train_dataset=train_data )
Train.py
import torch
import numpy as np
import pandas as pd
from transformers import BertTokenizer, BertForSequenceClassification
import transformers as tr
from sentence_transformers import SentenceTransformer
from transformers import XLMRobertaTokenizer, XLMRobertaForMaskedLM
from transformers import AdamW
from transformers import AutoTokenizer
from transformers import BertTokenizerFast as BertTokenizer, BertModel, AdamW, get_linear_schedule_with_warmup,BertForMaskedLM
from transformers import DataCollatorForLanguageModeling
from scipy.special import softmax
import scipy
import random
import pickle
import os
import time
import subprocess as sp
torch.cuda.empty_cache()
start=time.time()
device = torch.device('cuda') if torch.cuda.is_available() else torch.device('cpu') print("Using", device) torch.backends.cudnn.deterministic = True
tr.trainer_utils.set_seed(0)
print("here")
tokenizer = tr.XLMRobertaTokenizer.from_pretrained("xlm-roberta-large",local_files_only=True) model = tr.XLMRobertaForMaskedLM.from_pretrained("xlm-roberta-large", return_dict=True,local_files_only=True) model.gradient_checkpointing_enable() #included as new line print("included gradient checkpoint")
model.to(device) print("Model loaded successfully")
df=pd.read_csv("data.csv") train_df=df.text.tolist() print(len(train_df))
train_df=list(set(train_df)) train_df = [x for x in train_df if str(x) != 'nan']
print("Length of training data is \n ",len(train_df)) print("DATA LOADED successfully")
train_encodings = tokenizer(train_df, truncation=True, padding=True, max_length=512, return_tensors="pt") print("encoding done")
data_collator = DataCollatorForLanguageModeling(tokenizer=tokenizer, mlm=True, mlm_probability=0.15) print("data collector done")
class SEDataset(torch.utils.data.Dataset): def init(self, encodings): self.encodings = encodings
def __getitem__(self, idx):
    item = {key: torch.tensor(val[idx]) for key, val in self.encodings.items()}
    return item
def __len__(self):
    return len(self.encodings["attention_mask"])
train_data = SEDataset(train_encodings)
print("train data created")
 output_dir='results_mlm_exp1'
,logging_dir='logs_mlm_exp1'        # directory for storing logs
,learning_rate=2e-5
,logging_steps=500
,num_train_epochs=20
,bf16=True #Ampere GPU
trainer.train() print("model training finished") trainer.save_model("model_mlm_exp1")
print("training finished")
end=time.time()
print("total time taken in hours is", (end-start)/3600)
Error
subprocess.call('gsutil cp -r /pythonPackage/trainer/model_mlm_exp1 gs://******/model_mlm_exp1', shell=True, stdout=subprocess.PIPE)
ERROR ResumableUploadAbortException: 409 The object has already been created in an earlier attempt and was overwritten, possibly due to a race condition.
MAC
  • 277
  • 9
