When solving backward data-flow problems, many resources (Wikipedia and many presentations found online) recommend traversing the control-flow graph (CFG) in post-order for fastest convergence, which makes sense.
Other resources (such as the "Engineering a Compiler" book) suggest to use reverse post-order (RPO) on the reversed CFG instead.
... and PO(graph) != RPO(rev(graph)) in some cases involving cycles.
My question is: which resource is right? Post-order makes sense, so why not just use that and save the CFG inversion? Why would I use RPO on reversed CFG instead?
D.W.
  • 167,959
  • 22
  • 232
  • 500
It is mostly due to the speed of convergence. To clarify, RPO visits as many predecessors possible before visiting a node so in case of forward data flow problems (like Dominator computation) this would help to converge faster. You can find more details in Engineering a compiler book (which you already know!)
