I encountered a problem, where I am given a (fully-connected) graph within a metric space, where each edge weight is either 1 or 2.
My task is to prove that the following greedy algorithm gives a $\frac{3}{2}$-approximation for finding a TSP path: Start from an arbitrary node, pick the nearest neighbour node, go to this node and pick its nearest neighbour. Procedure is repeated until all nodes are picked, so that a valid cycle is produced.
I have seen more advanced techniques to solve the problem more efficiently here, which, however, did not help me.
My attempt was: Take any 3 nodes. Since we have a fully connected graph, the edges between the 3 nodes must form a triangle, and since we have a metric space, possible triangle sides are: $\{ (1,1,1), (2,2,2), (2,2,1) \}$. Since we are looking for path, we will never take all sides of this triangle, but at most 2. Since we always make our choice greedily, if the triangle is with sides $(2,2,1)$, we will never pick the 2 sides of length 2 together, but we will pick a side of length 1, and a side of length 2, hence resulting of weight from this triangle is 3.
I am stopping here, as I am not confident already.
