I need to decrypt a huge file that I own previously encoded by myself with a RSA public key (it's possible for this step using a symmetric algorithm key). Problem is that I can't load it in my disposable memory for specific embedded architecture reasons.
I need to decrypt it with the private key associated to the identity of that architecture (or the shared symmetric case if there were the algorithm chosen). I want to know if its possible to decrypt the file loading it in memory by parts and decrypting each of them, without losing security against brute force attacks. As far as I know, in a typical RSA encoding process first you transform the whole char string that is the file into a number, to be encrypted, so my assumption is that is not possible in a typical RSA encoding-decoding process. However, as I have the file I can encrypt it line by line or char by char, instead of encoding the whole, to decrypt it later again slice by slice. I'm assuming that a line or a char after encryption would have the same length in bytes, which may be a wrong assumption.
EDIT: Let's complicate things a little bit more: After decrypting through RSA or symmetric key, I'll have to encrypt again the slices of my huge file, this time with a RSA public key. So, first: Encrypting huge file on a custom basis to make it decryptable part by part; second: take each part and encrypt it with RSA.
Is this a feasible solution? Am I losing efficiency and would be more exposed to brute force attacks?
EDIT2: Keysizes would be the typical for opensource implementations: a minimum of 256bits. I've to investigate the hybrid encryption, can't tell yet. When I say a line I mean chunks of data of, let's say, 50-60 chars. I pretend to encrypt-decrypt a binary file, so char length doesn't matter (consider them 1 bytes ASCII if it helps)
