16
Suppose we have two people: Smith and Jones. Smith public key is e=9, n=179 and Jones public key is e=13, n=179. Bob sends to them a message $M$.
The encrypted message $C_s$ to Smith is 32.
The encrypted message $C_j$ to Jones is 127
I tried to resolve this problem with no luck.
First I put both of them as an equation and tried to play with the module, multiplying and adding, but I can't retrieve the solution. I know there is a way to resolve it but I haven't found it anywhere.
EDIT: Is not a realistic situation. Is just for practice. This is the primitive RSA. It has no padding.
I'm beginning to think that the problem is wrong maybe because the results I get are not correct.
This is the original problem text:
Imagine that you are a CIA double agent. As good spy, you have discover that the agents Smith and Jones share the same modulo in their respective RSA public keys, namely ($e_s$ = 9, n = 179) and ($e_j$ = 13, n = 179). After some days sniffing the network, you see that the CIA director has sent the same message m to both agents. Concretely he has sent $c_s$ = 32 and $c_j$ = 127. Can you recover the original message m?.
Solution m = 10
Resolution by me:
So I have the following equation:
$c_s$ = $m^9$ $mod$ 179
$c_j$ = $m^{13}$ $mod$ 179
And I began to use the extended Euclidean algorithm:
9*$a$ + 13*$b$ = $gcd$(9,13) which gives me:
$a$ = 3 and $b$ = -2
As $b$ is negative, we calculate:
$i$ $=$ $c_j^{-1}mod179$
the inverse of $c_j$ (127) which is $-31$
And finally:
$M$ = $c_s^a$ * $i^{-b}$ $mod$ n
$M = 32^3*{-31}^2$ $mod$ $179$ $=$ $10$
Great! thanks!!!
Tomas
  • 163
$c_1 \equiv m^{e_1} \bmod n$
$c_2 \equiv m^{e_2} \bmod n$
if $\gcd(e_1,e_2)=1$ then $\exists a,b\in\mathbb{Z} : e_1\cdot a + e_2\cdot b = 1$ ($a$ and $b$ can be found by extended euclidean algorithm)
And,
$m\equiv c_1^a\cdot c_2^b \bmod n$
Note: In practice, either $a$ or $b$ will be negative. WLOG, let $b$ be negative. This leads to problems in the above equation. To get around this, use the following computation.
Let $i\equiv c_2^{-1} \bmod n$ (i.e., the modular inverse of $c_2$)
$m\equiv c_1^a\cdot i^{-b} \bmod n$
Update to show details of $m\equiv c_1^a\cdot c_2^b\bmod n$. All math below done modulo $n$.
$$ c_1^a\cdot c_2^b\\ (m^{e_1})^a\cdot (m^{e_2})^b\\ m^{e_1a}\cdot m^{e_2b}\\ m^{e_1a+e_2b}\\ m^1\\ m $$
mikeazo
  • 39,117
  • 9
  • 118
  • 183
